There are three different versions or I should say I have schematics for three versions. The first one is just SUMO NINE, the second two are NINE+. Determining which of the +s you will need to see what type of output transistors it uses. The first + uses 2SC1831s and the second uses 2SD555s. I have the NINE schematic loaded up and ready to go, the NINE+s I'll have to do some digging. I have tons of schematics in no particular order, unfortunately.
Craig
Craig
Sumo Nine
Thanks for the info could you send this drawing of the Sumo Nine amp that you have ready to send.
edoherty@cableone.net
Thanks a lot
Ed Doherty
let me know what you think of this amp or any of the others that you have. Sound Quality
Thanks a lot
Ed Doherty
