Old 20th December 2009, 02:36 AM   #1
Send a message via AIM to Spasticteapot
Default Can someone here help me figure out if I've laid out my schematic correctly?
As a college student, I am, not surprisingly, pretty broke. As such, I'm designing an amplifier that uses a tiny PCB, can be built entirely using through-hole parts, and is comprised entirely of ICs that our good friends at National Semiconductor will give us completely free. This is my first attempt at anything more complicated than a GainClone PCB, and I was hoping that someone could check my work.
The amplifier is pretty simple - it's the reference design from the datasheet of the LME49600, a BUF634 clone manufactured by NatSemi. It's a basic "op amp with a buffer in the feedback loop" design, with the addition of a servo to eliminate voltage bias (which I think should be bypassable by removing a few parts and adding a jumper - am I correct in this assumption?)
http://www.national.com/an/AN/AN-1768.pdf
I've laid out the schematic in EAGLE, and would appreciate it if someone could take a look and check to see if I've done something stupid. It's functionally the same as the one in the schematic, though a few parts (mostly power supply caps) have been swapped. Also, the two dual op-amps have been swapped with a quad op-amp from the same series.
RapidShare: 1-CLICK Web hosting - Easy Filehosting
Also, I was hoping that someone could check if the following parts are sized correctly - I'm not quite sure if I'm reading the datasheet right. I also couldn't find the Molex connector in question on Mouser - if it's the one I think it is, it's pretty common, and if anyone could point it out I'd appreciate it.
10UF caps:
EEU-FC1H100L Panasonic Aluminum Electrolytic Capacitors - Leaded
120UF caps:
EEU-FC1E121 Panasonic Aluminum Electrolytic Capacitors - Leaded
1UF caps:
MKS4-1.0/100/10 WIMA Polyester Film Capacitors
Old 20th December 2009, 04:17 AM   #2
Here's a picture:
How to correctly use WinISD Zero D Subwoofers 18 24th April 2011 03:40 AM
Bob Pease laid off SY Everything Else 11 18th March 2009 09:05 PM
Am I using Unibox correctly? zimjj Multi-Way 0 7th February 2009 11:26 PM
Are we looking at distortion correctly? mashaffer Solid State 24 14th July 2004 03:04 AM
diyAudio is laid out so well purplepeople The Lounge 3 12th August 2003 07:55 PM
Page generated in 0.07550 seconds (72.53% PHP - 27.47% MySQL) with 10 queries
