Describing that "ON" noise in old SS equipment
Old 19th December 2009, 07:18 PM   #1
6f6 is offline 6f6  United States
Default Describing that "ON" noise in old SS equipment
How would one describe the "ON" noise that one usually gets in 1970's era solid state equipment electronics? I just put my McIntosh C-28 preamp up for sale at Ebay; I described the sound as "white noise"- kind of like air draining out the hose from an air compressor. This is not hum or squeal- I know what causes those. Would this be more accurately described as "transistor noise"? Do you guys use other words to describe it?
Old 19th December 2009, 07:21 PM   #2
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Faulty?
Old 19th December 2009, 07:33 PM   #3
Rafael L is offline Rafael L  Brazil
White-noise and Pink-noise is used to make measurements on loudspeaker, in equipment electronics is used to SNR for measure noise
Old 19th December 2009, 07:37 PM   #4
Not faulty, just old. All the old SS equipment make this sound, its not a bad part, I'm guessing that it is an issue stemming from the interelectrode capacitances of older BJT transistors- they charge and discharge and create a very low noise floor
Old 19th December 2009, 07:47 PM   #5
Glowbug is offline Glowbug  United States
Glowbug's Avatar
Has it been re-capped?
Jim
The machine does not isolate us from the great problems of nature but plunges us more deeply into them. - Antoine de Saint-Exupéry
Old 19th December 2009, 07:51 PM   #6
dhaen's Avatar
Sorry 6F6 that was just my odd sense of humour...
However, I'm still not sure what you mean. I do remember when this "ilk" of kit was new, but don't remember any strange noises, except in the occasional badly designed one. I doubt there's anything iffy about the McIntosh's design.
Old 19th December 2009, 07:53 PM   #7
Electrolytic capacitors should be aged, filtering the power supply is not good as when the equipment was new...
Old 19th December 2009, 08:18 PM   #8
No, I did not recap it. I know that leaky electrolytics usually cause hum.
Old 19th December 2009, 08:35 PM   #9
Yes is hum, not is this noise that you have?
Old 19th December 2009, 09:11 PM   #10
Not hum. If there was hum, I would have replaced the electrolytic caps. My guess here is that it is transistor or resistor noise. This noise may have very well been present 30 years ago- it is very common to classic 1970's solid state equipment. I guess that I'm a bit picky; I DIYed a tube-based preamp and tweaked it until nothing could be heard with the volume all the way up.
Describing that "ON" noise in old SS equipmentHide this!Advertise here!
Anyone know some decent free SPL meter software & "white noise"? Spasticteapot Multi-Way 18 6th October 2011 10:05 PM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 07:42 PM
"test equipment blowout" lgreen Swap Meet 0 28th June 2005 09:28 PM
suggestions for the "lowest noise" pentode Majestic Tubes / Valves 6 1st December 2004 10:42 AM
A "Standard Noise Source" for SPL meters. Jonathan Bright Everything Else 6 13th July 2004 11:19 PM
Copyright ©1999-2017 diyAudio
