Old 20th March 2010, 03:23 PM   #1001
destroyer X's Avatar
Default Very unkind comment BV, your should try to be more educated
We are putting the wheel to run.... others, maybe you, will prefere to sit over the wheel.... i hope with some pleasant moments with the wheel, you may turn more kind.
Not having anything clever, or kind to say, it is better not to say things.
Carlos
Try to build an amplifier folks ... it is pure adrenaline!.. when not work first time, then becomes a nice challenge...and we usually overcome the trouble... and we feel very well to be mastering the machine.
Old 20th March 2010, 03:46 PM   #1002
wahab is offline wahab  Algeria
Originally Posted by BV View Post
Reinventing wheel, gentlemen?
Slones 11.4 'Blameless'
It is very old idea, in many books and schematics. And capacitive loading VAS with 470pF to GND is very suboptimal way to stabilize amplifier- loading means increased distortion at higher frequencies.
Hi, bv..
The idea is way older than slone or doug selfs designs..
as far as i remember, it was vastly used in japanese
amps by the 70s, so the reference you mention also
reinvented this wheel...
Anyway, what was discussed was not the enhancement
of the Vas, but the current limitings around this stage..
About this, i will add that a resistor in serial with the bc546
protect only this one from excessive currents, while using
a zener allow current limiting of both bc546 and bd139 vas.
Old 20th March 2010, 04:50 PM   #1003
Originally Posted by godfrey View Post
Hi Carlos
Perhaps you could put a resistor at the collector of Q6, to drop some voltage and share the power?
Regards - Godfrey
Originally Posted by wahab View Post
This idea work, godfrey, but then, this transistor s collector will see a signal appearing due to the transistor functionning in a common emitter mode.
So a capacitor should be added in paralel with this resistor to keep
the collector in ground in AC mode...
q6 is effectively a constant current fed emitter follower.
A resistance in the collector to ground lead will see a nearly constant voltage drop even when the VAS and it's EF are passing audio signals.
Add in this extra resistor to limit the dissipation in the To92 device. I think this was suggested about 5months ago.
regards Andrew T.
Old 20th March 2010, 04:58 PM   #1004
PMA is offline PMA  Europe
PMA's Avatar
BV is right, capacitive loading of VAS to GND is probably the worst possible compensation method.
Pavel Macura, consultant
http://cz.linkedin.com/pub/pavel-macura/4/783/637
Old 20th March 2010, 05:26 PM   #1005
Agree, pavel , but only in the case of a single differential amp.
With a symetrical differential, Vas collector to ground compensation
can work quite well.
Old 20th March 2010, 05:35 PM   #1006
BV is offline BV  Slovakia
Hi, wahab
It was no reference, only example how can it (current limiting in VAS) be done other way, avoiding also VAS saturation and rail" sticking"..
Anyway, loading VAS iwith capacitor is worsening its linearity and SR, excessive current is needed.
Old 20th March 2010, 05:39 PM   #1007
taj is offline taj
taj's Avatar
Pavel (and BV, and Eva too for that matter),
I thought it was obvious given how many years Carlos has been here talking about this, but apparently not, so listen up: Carlos has priorities with his projects:
1) great sounding amplifier
2) stable within reason
3) easy and cheap to build for anyone
You will notice there is no mention of distortion in that list. There are other threads for that. Eva, I refer you to item #3.
..Todd
Old 20th March 2010, 06:06 PM   #1008
Hi, wahab
Well, i m somewhat off topic, but just want to mention that
i used to think so as well till i did some tries and had some
good results with this much decried way of compensation scheme.
As i mention it, it didn t work with simple differential topology
but with a symetrical differential ,it yielded some fairly good
specs when the amp wa loaded with a complex load...
Old 20th March 2010, 06:09 PM   #1009
PMA's Avatar
He is not the only one, so please refrain from empty words. We are trying to point at obvious mistakes, I have not said a simple word about THD.
Old 20th March 2010, 07:24 PM   #1010
tinitus is offline tinitus  Europe
Just want say todays posts have been a pleasure
Blameless, Dx was wrong, it is a very good amplifier destroyer X Solid State 125 2nd November 2007 11:57 PM
Blame Canada. herm Everything Else 14 19th August 2006 02:38 AM
Page generated in 0.11787 seconds (77.55% PHP - 22.45% MySQL) with 11 queries
