OK,
I've got a discreet "op amp" type preamplifier similar to: http://www.diyaudio.com/forums/attac...amp-yadopa.jpg Except the input FET's are in a single package. And it doesn't work - doesn't pass a signal and the output voltage is up against one rail. Because the design is all direct coupled, I don't know how/where to start looking for a problem - other than removing and testing every transistor. Can anyone suggest (or point me to) a "systematic / generic" way to troubleshoot this? Thank You Charles |
#2 |
the secret is getting the dc bias conditions right...
First, ground both inputs...the grab a DC meter. J1 is a constant current diode...I don't know the current it's set for, let's assume 2 mA, under this assumption, Then there should be 1 Volt across R34. If there isn't, you've found the problem. Work your way from left to right, checking all the DC voltages, across R55, R20, R7...they should be quite similar...you can compare it to your spice simulation, if you have one...(does spice think this works?) Hopefully this will help...post more info as you have it... |
#3 |
Sorry about that mistake, you could go back and check the "Yet another discrete op-amp thread" for the fix and further discussion. If problems continue you can PM me.
2012, our time is running out. |
| Troubleshooting hum in 12b4 preamp.. finally almost done!! | 240z4u | Tubes / Valves | 60 | 29th October 2010 07:01 PM |
| Need help troubleshooting preamp trouble | Captn Dave | Tubes / Valves | 7 | 19th September 2008 02:18 PM |
| n00b phono preamp troubleshooting.. | Miniwatt | Tubes / Valves | 6 | 31st May 2007 01:16 PM |
| Parasound Preamp Troubleshooting | mura | Solid State | 3 | 26th January 2005 11:31 PM |
| Troubleshooting Problem in Tube Preamp | Audiofng | Tubes / Valves | 3 | 13th February 2003 11:12 PM |
| Page generated in 0.08199 seconds (72.55% PHP - 27.45% MySQL) with 10 queries |
