Hello,
I would like some help in fixing a thermal problem with a Adcom GFA-5400. Does anyone know a part number or Digikey # for the thermal switch between heatsink and PCB? Any advice on ordering from Adcom? Any advice on repairing this? It looks like a complete disassembly. I have ordered the service manual off www.stereomanuals.com Does this have part #'s? The left channel will not play. The left thermal protection LED is on. The Thermal switch is open. Adcom GFA 5400 copyright 1995 from PCB X-1232A03T Serial: A541FB 05295 Thanks, Blair Sutton |
#2 |
Hello Blair,
Any luck with your problem? On my 5400 the LED Thermal Protection light is on the right side. It stays on for about 1/2 hour then turns off and both speakers play. Then when I turn off the system the LED light turns on again after the amp cools. I took the cover off and checked for dust and looked at the internal fuses. I am just wondering if this is something I can live with or will it get worse! So long for now! |
#3 |
If the thermal switch is stuck open (i.e. it's staying open even though the amp is off and entirely cooled down), you can try a trick we used to do working on laser printers: freeze the hell out of it with freeze spray, and see if it closes back up again.
#4 | |
I would not know where to use it! I would have to get my hands on a manual. Thank you very much for your help! It is a shame that there is no reset switch! That would be to easy!! |
| A75 and adcom gfa-5400 | ctong | Pass Labs | 88 | 7th August 2009 09:04 PM |
| Yet another Adcom GFA-565 problem | Lockport | Solid State | 30 | 24th July 2009 03:42 AM |
| Adcom GFA-5400 | kenscott30 | Swap Meet | 0 | 4th December 2005 05:08 AM |
| Adcom GFA-555II problem | oscarav098 | Solid State | 2 | 10th November 2005 03:47 PM |
| Adcom GFA 7500 channel problem | G-Rock | Solid State | 2 | 19th May 2005 02:09 AM |
| Page generated in 0.07564 seconds (71.67% PHP - 28.33% MySQL) with 10 queries |
