Old 18th December 2009, 03:35 PM   #1
kibi is offline kibi  United Kingdom
Default Giesberts IGBT amplifier Elektor 1995
Hi
I have decided to build some of these amplifiers. I last built them 13 years ago and liked them very much.
My question is, what LED's do you use? I don't have any more of the ones that I used originally and I want to order the correct ones.
Old 19th December 2009, 02:28 AM   #2
Bigun is offline Bigun  Canada
Bigun's Avatar
I've no idea what this amplifier looks like, can you post some details, it sounds interesting.
LEDs - can't see that this is very critical. There are some tests somewhere showing noise levels for different brands and colours, but if anybody is brave enough to tell me they can hear a difference I'll consider buying them a beer
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 19th December 2009, 01:11 PM   #3
wahab is offline wahab  Algeria
from this times, there s two schematics at elektor using IGBTs...
one use a complementary differential and the other one
is a current feedback amp..it seems that the former is
the 1995 model...
Old 19th December 2009, 01:15 PM   #4
Default schematic of elektor s igbt amp of 1995
hope this will help..
Old 19th December 2009, 06:21 PM   #5
meanman1964's Avatar
There is a kind of update of this amp that uses the IRFP240 and the IRFP9240 mosfets instead the IGBT.I can send you the update if you want.With the update no more worries about oscillation-probs
Old 19th December 2009, 08:46 PM   #6
AMV8 is offline AMV8  United Kingdom
Meanman 1964
I built the original amp. I was not aware of an update using the IRFP mosfets. I would like a copy if possible so as I have lots of the IRFP mosfets and I would like to build the updated model to compare the sound. PLease either post here or send to my e mail address.
Don
Old 19th December 2009, 11:21 PM   #7
Originally Posted by AMV8 View Post
Meanman 1964
Don
It isn't an update from elector but from someone who had probs with this amp caused by oscillations of the IGBT.Did you have those probs too?the schematic is called the Hexfet amplifier but it's from the IGBT version.All what's in orange is the update but look out the partnumbers on the updated schematic ain't number the same as the original IGBT schematic.
Old 19th December 2009, 11:26 PM   #8
BMW850 is offline BMW850  Netherlands
BMW850's Avatar
Another one scheme , from Analog Devices.
http://www.analog.com/static/importe...17334AN211.pdf
It’s not what you know, but who you know “and where they are”
Old 20th December 2009, 10:31 AM   #9
Thanks for the replies.
I have never had any problems with the original amplifier with IGBT's. It seems to work fine. My speaker loads are around 4 ohms and with little/no crossovers.
I also have a couple of Forte amps that use IGBT's and no problems from them either.
However I am interested in listening to the difference if the output devices are changed to IRFP devices. I would like to see if the IGBT's improve anything or make things worse or make no difference. The theory behind IGBT's seemed ok but I am not sure if they really work in practice. I will have a go over Christmas and let you know how it sounds.
Don
Old 20th December 2009, 01:53 PM   #10
The LED's in question are thermally coupled to T5 and T6 in the circuit diagram that wahab attached earlier in this thread. They are supposed to have a 1.6V drop at 3mA. Trying to find an LED with those specifications is proving to be difficult for me.
Balanced IGBT for amplifier output Lazy Cat Solid State 164 4th June 2011 11:17 AM
Compact Power Amplifier from Elektor jazzpeter65 Solid State 127 5th March 2010 04:34 PM
Elektor PA 300 amplifier supernet Elektor 10 13th February 2008 05:13 PM
Replacing IGBTs with BJTs in Elektor IGBT design! Shahriar Solid State 9 25th March 2007 07:52 PM
Page generated in 0.10219 seconds (78.66% PHP - 21.34% MySQL) with 11 queries
