Old 18th December 2009, 12:32 AM   #1
Default Accuphase e202 right channel quiet
Hello,
I just got an Accuphase e202 that worked great for a couple weeks (other than a crackly volume pot) but I just noticed today that my right output channel is not as powerful as my left.
I have switched my speakers around and tried all the different output mode combinations but the output from the left channel is always about 10dB lower. (as read off the VU meters)
I have copies of the schematics but don't know where to start my trouble shooting.
Could anyone offer some advice on where to start with solving this problem.
Any input is much appreciated.
Old 18th December 2009, 11:58 PM   #2
If no one has any specific advice on troubleshooting a quiet channel on an accuphase e202 can anyone recommend any online resources where I could learn about troubleshooting an audio amplifier in general?
I'm just wondering what kind of faults to look for and which components might usually be responsible for such a problem.
Thanks.
Old 27th December 2009, 09:18 AM   #3
I got an used E-202 recently; it is functioning with one fuse lamp burned out. I figured out that the contacts of the selector switches are not so good. I think this is reasonable since the amp is built more than 30 years ago. You can play with the switches and see if you can find anything wrong in the switches. I openned the chassis today trying to figure out the type of fuse lamp and also figured out that it is not easy to service this amp since it is so old. I could not pull out the power amp circuit board. Would you please share the schematic with me? I am curious about the mid-size electrolytic cap sitting on the power amp PCB.
Old 27th December 2009, 11:30 AM   #4
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
You can find the complete Service Manual here:
www.audio-circuit.dk Free Downloads
If the fault is present whatever input you select, I wouldn't suspect the switch......
It's more likely (and happely) just a bad solder or a faulty component which can be fixed with a new........
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com
Old 30th December 2009, 01:29 AM   #5
Yes, the fault is present no matter which input so I expect it is a component or solder joint.
Which part of the circuit would be a likely place to start and which components would be likely culprits when the symptom is a quieter signal out of one channel?
Can I do this kind of trouble shooting with a multimeter or do I need to dig out an oscilloscope?
Thanks!
Old 30th December 2009, 04:23 AM   #6
Jan Dupont's Avatar
As I recall you can separate the pre and poweramp on the back side ?
If so start by finding out if it is the pre or poweramp that has the fault.....
It can be difficult to find a fault like this with a multimeter, however you can be lucky.
There are written some DC readings different places in the circuit on the schematic in the service manual. Start there and let us know.
Old 30th December 2009, 02:21 PM   #7
Thank you Jan, I will post my findings here.
Accuphase e202 repair glen27 Solid State 5 2nd April 2011 06:41 PM
One channel quiet - any bright ideas? Rob11966 Tubes / Valves 4 12th April 2009 02:57 PM
accuphase e202 glen27 Solid State 9 5th April 2009 10:03 PM
How quiet is dead quiet? pchw Tubes / Valves 36 22nd November 2007 04:36 AM
wtb- E102, E202 or other CRD Panelhead Parts 1 20th February 2006 03:19 PM
Page generated in 0.08216 seconds (78.61% PHP - 21.39% MySQL) with 10 queries
