Old 17th December 2009, 12:01 PM   #1
sakis is offline sakis  Greece
sakis's Avatar
Default torodial transformer question
i am messing up with a Marantz amplifier that is doomed beyond any repair ...
the box is actually really spacy so i was thinking to use the preamplifier and selector section as is
then use another board for the amplifier which will require diferent trafo than allready existing
space and dimenesion wise i have area enough to fit two torodials 250w each but mounted on a top of each other
do you think that this might cause any complication ????
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 17th December 2009, 12:16 PM   #2
quasi is offline quasi  Australia
quasi's Avatar
Ti kanis levendi?
I have mounted toroids on top of each other without any problems with a single bolt. Use the toroid base plate plus the rubber bushing between them. I would say 2 is the limit though because of the bolt tension required.
Yia
Quasi
Old 17th December 2009, 01:36 PM   #3
Nrik is offline Nrik  Denmark
In my 15+ years old Aragon 4004 MKII there are two 800VA toroids on top on each other.
So if there is no problem of use in a popular amplifier, sold in a decent amount of copies after many years , you should be okay with it.
STOP - Hammertime!
Old 17th December 2009, 02:54 PM   #4
sakis's Avatar
i am just fine con .... thanks for your ineterst ....by the way all your amps are hapilly runing ( 4 so far made ) all of them working in small PA use or abuse ha ha ha ha
so far no protections no limmiters or so but also no problems at all ....
i have designed my wonderfull limmiter, boards are ready but since its xmas we are very busy so amps will keep working with out limmiters until farther notice ...
kind regards (καλη χρονια υγεια και αγαπη για σενα και την οικογενεια σου )
xmas creetings in greek form my friend con and famliy
thanks
Old 17th December 2009, 07:29 PM   #5
nigelwright7557's Avatar
Originally Posted by quasi View Post
Ti kanis levendi?
Yia
Quasi
Its OK having 2 torids on top of each other so long as the bolt doesnt touch the top of the metal case and cause a shorted turn.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 17th December 2009, 11:44 PM   #6
Bonsai is offline Bonsai  Taiwan
"Its OK having 2 torids on top of each other so long as the bolt doesnt touch the top of the metal case and cause a shorted turn. "
LOL - good one. I had some colleagues who built identical amps (this is many years ago) and placed the main chassis earth point on the bolt holding the toroid. Plenty of hum until they worked out the problem!
bonsai
http://www.hifisonix.com/
Old 18th December 2009, 07:44 AM   #7
sakis's Avatar
yes yes ..... i ve made the same mistake when i was a kid
while constructing a quiet big amp ( the trafo was 1.5kw 48+48 ac ) the mechano arround it suported a screw that was long enough to be bolted from up side and down side so i think at the time since the trafo is so big it would be very nice to bolt it from both sides to keep it very stable
amp wokred just fine passed all testings until the final assembly and the top cover installed ...after that amps draw and a big zzzzzz sounded from the short in the trafo
took me some time to figer it out .... but wtf at the time i was 17....... ha ha ha ha
Output regulator after torodial transformer? freestylez Power Supplies 9 25th June 2009 01:46 PM
torodial transformers? monomonster Parts 23 17th October 2005 08:48 AM
WTB: dual 45-55v torodial transformer ycl Swap Meet 1 23rd March 2005 06:48 PM
Torodial Tranformer Calculation JanDH Parts 34 28th December 2003 02:34 PM
Page generated in 0.09493 seconds (78.04% PHP - 21.96% MySQL) with 10 queries
