Old 16th December 2009, 02:34 PM   #1
sfox50 is offline sfox50  United States
Default Old BGW 550D
I'm resurrecting an old 500D, it's the 7 inch version with the amp boards/heat sinks on the top of the case. I have replaced the PS caps with new Nichicon 21000 uf 80V , replaced the bridge rectifier (just to be safe), and installed an IEC socket for the power cable. The fan was quite noisy- I tried replacing it with a newer AC fan, but I still hear it at times. Would it be OK to run it with the top cover off & no fan? I'm running MMG's, so I do use the power that's available. Also- should I replace the Sprague electrolytic caps on the boards, or maybe bypass them with film caps? There is a single op-amp on each board- would it be good to update those? Thanks for whatever help you can offer!
Old 17th December 2009, 09:04 AM   #2
djk is offline djk
djk's Avatar
No fan=heat death.
Opamp, don't change.
Output stage on older ones will be quasi-comp, newer one shown here.
Replace the C1, C3, C11, C12 with new, and add a film bypass. Add a pair of 47µF bypass caps to main filter caps. Change all ceramin caps to film or silver mica (as appropriate for values).
Candidates for the Darwin Award should not read this author.
Old 17th December 2009, 01:20 PM   #3
djk- thanks for the quick reply. The fan & top cover will go back on! I have the manual & schematic ( generic, for the 500D & 750D). The C1 cap is shown as a 10UF 25V Tantalum, what should I use to replace that? What would be good to use for the film bypass? Thanks again!
Page generated in 0.07293 seconds (70.33% PHP - 29.67% MySQL) with 9 queries
