Old 13th December 2009, 08:15 PM   #1
SimonB is offline SimonB  United States
Default Need help troubleshooting an amplifier...
I have a Telex EV SonicXS 4.1 sound system for my computer and I have had it for about five years. I've had a problem with it working properly. I'll turn it on and it makes a loud noise like AM-radio for about a minute, then that noise goes away and the subwoofer doesn't work and the satellite speakers sound like they are missing the treble. Then there's the AM-radio noise again and then suddenly a pop and everything sounds great. At least that's the way it usually happens.
Well I took apart the subwoofer which houses all of the amplifiers and crossovers. There are five small boards that look like the individual amplifiers for each speaker. There is a burnt smell and the board is burnt around the leads of a big resistor. The color coding on the resistor comes to 68 ohms, and I tested the resistance with my digital multimeter and it says 69 ohms so it looks good.
I can't find schematics anywhere online for this system. Are there any additional troubleshooting steps you guys can recommend?
Here are a couple pics of the amp and the burnt area on the board:
Old 13th December 2009, 08:26 PM   #2
The picture shows a couple thermally worked solder joints for some signal resistors going by that over powered power resistor. The power resistor is fine, but retouching all those solder joints would be step one.
Old 14th December 2009, 01:02 AM   #3
49 - for the 16th time
c2cthomas's Avatar
Seems that you have done the 1st thing which is a good visual check of things.
For something that is a thermal intermittent like this a shot of freeze spray Parts-Express.com:*ECG RX100-10 Antistatic Circuit Refrigerant 10 oz. | refrigerant freeze spray chiller chemical electronic chemicals in suspect areas can help to make the targeted component(s) act up. Some type of heat gun (hair dryer? don't let her catch you with it tho) to blow hot air can be helpful.
"You can't always get what you want" K. Richards/M. Jagger *** "Next time I will know some things better" Zen Mod
Old 14th December 2009, 01:06 AM   #4
i would change those electrolitic caps next to the burn mark as well they might have dried out a bit.
Amplifier Troubleshooting. 5th element Solid State 181 15th April 2009 04:20 PM
Help me troubleshooting amplifier module fosforo Solid State 15 7th November 2006 10:59 AM
help troubleshooting amplifier/receiver please JMB Solid State 6 25th October 2004 04:14 PM
amplifier troubleshooting question Randy Knutson Solid State 16 21st August 2003 03:15 PM
amplifier troubleshooting sriegel Solid State 0 6th April 2002 05:28 PM
Page generated in 0.08315 seconds (75.39% PHP - 24.61% MySQL) with 10 queries
