so, yesterday i did first run...oscillation on both channels...input shorted, oscillation will increase
maybe you can try to install 22pf instead of c5 (15 pf) / lead compensation capacitor... how many ampere do you set bias for your amps?
use bulb test for the first run test for your amps safety...
Best Regards
Add another 10 pf in parallel and test again.10pf...i have to order 15p MICA...
Calor LTSpice sim
This is old thread, but since I have good working model of Calor amp, I thought I would publish it here, if anyone interested.
Seems like a great A Class amp. Idle current: 1A per output device.
Fine!enjoy the music.
Maybe i must built the second channel.
The most expensive part is the transformer,that's why i had stop the project.
Hello Thimios, due to mr Bora can not help in this amp. build anymore , it would be great if you can share with other people his files .
Kind regards,
Lucca
- Calor amp 40 Watts Class A
