Hi, I'm new here so I hope this is in the correct forum, if not can it be moved? Anyway, back to my question, I am in need of some 2SA939 transistors but they do not seem to be availabe anymore. Can somebody recommend me a replacement part number that will work in place of the 2SA939 and be close enough in performance that there is no audible difference? Thanks for any help and suggestions.
#2 |
According to a "Bipolar Transistors Cross Reference" from SGS-Thomson, MJE350 should cross pretty well...check a few basic things...NPN vs. PNP, as a sanity check...some Japanese references I saw made the basic voltage ratings look plausible...good luck...
#3 |
Thanks! You know, those are cheap enough, so I'll just order a dozen or so and give it a shot. Thanks for the suggestion!!
#4 |
Are they used as part of a complementary pair NPN/PNP driver stage ?
If they are might be worth looking to replace as a pair MJE340/350 Old Jap transistors often fail open circuit base emmiter for some unknown reason. |
#5 |
Good idea, they are actually. The other ones in the circuit are still good, but would it be a good idea to change them anyway so that I have complementary pairs that are more similar?
#6 |
These are more up to date, a list I keep for reference,
| Looking for replacement transistor | kockaboy | Parts | 4 | 15th October 2008 04:51 PM |
| transistor replacement | xcicc | Solid State | 0 | 16th August 2008 10:05 AM |
| Transistor Replacement | portlandlay | Solid State | 26 | 14th December 2005 07:46 PM |
| Transistor replacement | Mlaen | Solid State | 3 | 18th February 2005 11:00 AM |
| Page generated in 0.07695 seconds (75.82% PHP - 24.18% MySQL) with 11 queries |
