Old 11th December 2009, 02:13 PM   #1
Havenwood's Avatar
Send a message via MSN to Havenwood
Default Feedback OpAmp Question
Hi!
When we make a buffer opamp, like:
Use TL082, we have a global NFB factor of 110dB, with 0dB gain,
now, what about the musicality? What about TIM distorsion?
This is a 100% error amplifier?
Douglas Self use a NFB factor of 30dB @20kHz
From LCAudio: 100% non-feedback = 100% musicality!
L C Audio Technology/The End Millennium
From Altmann Splif:The Feedback is what my idea deals with
Feedback is good. Especially negative feedback. Especially global negative feedback. It makes the amplifier linear. It makes the amplifier fast. It lowers distortion. It must be used at all cost. Its just a great invention, maybe the greatest in audio.
How true!
Feedback is bad. Especially negative feedback. Especially global negative feedback. It enables the loudspeaker to speak back into the amplifier. It messes everything up. There is no more music coming out. It must be avoided at all cost. It is just a great culprit, maybe the greatest in audio.
How true!
The ALTMANN SPLIF Amplifier Topology
And we have zero feedback amp, low feedback amp, etc.
I am interested in other opinions, and I know that this is controversial and subjective.
Is bad idea use buffer opamp with audio signals?
- Music by John Williams -
Old 7th January 2010, 12:34 PM   #2
Telstar is offline Telstar  Italy
No reply... interesting
The response of the inner ear extends to at least 200khz - Dr W. Tempest
Old 7th January 2010, 12:42 PM   #3
Juergen Knoop's Avatar
no!
Old 7th January 2010, 03:57 PM   #4
jcx is offline jcx  United States
it is not possible to design a significant range of signal processing electronics without any negative feedback
the "no feedback" crowd either:
trys to deny the types of (local) negative feedback they use are feedback at all
or some allow for recognizing local feedback and reserve their definition of "bad feedback" as only refering to multiple stage or global feedback
it's also a trollish setting up of a straw man to use a 30 yr old op amp as your example - monolithic op amp performance has hugely improved since the TL084 was released while small signal discrete semiconductors for audio have mostly seen discontinued parts rather than improvements
Old 7th January 2010, 04:06 PM   #5
The second, with one addition - no feedback in the OPS.
Old 7th January 2010, 11:49 PM   #6
Bonsai is offline Bonsai  Taiwan
"Feedback is bad. Especially negative feedback. Especially global negative feedback. It enables the loudspeaker to speak back into the amplifier. It messes everything up. There is no more music coming out. It must be avoided at all cost. It is just a great culprit, maybe the greatest in audio.
How true!"
Have you been at the mushrooms again with Lumbar?
bonsai
http://www.hifisonix.com/
Old 7th January 2010, 11:55 PM   #7
scott wurcer's Avatar
Hi!
Positive feedback better!
Are you sure it's not Altmann SPLEEF topology.
2012, our time is running out.
Old 8th January 2010, 01:41 PM   #8
traderbam's Avatar
Spleef - Minepedia - The Minecraft Wiki!
You need to get out more, Scott.
“Simplicity is the ultimate sophistication.” Leonardo da Vinci
Old 8th January 2010, 02:11 PM   #9
Thinking more of the urban dictionary version
Old 8th January 2010, 02:19 PM   #10
Some op amps are not very good used as buffers . NE5534 is typical of one needing care , there is good advice in data sheets concerning this . I once asked the mathematician Micheal Geurzon ( spelling? ) what he thought about negative feedback . " I never have , if I had I might have said this . Some amplifier need a lot , some very little . You can bet most have the wrong amount " Michael went on to say an amplifier might have 3 or 4 stages , ideally it might have 3.5 stages . Michael died some time ago , his contribution to audio was filter design and improved microphone designs . I wanted to post his reply for all to read . Some may think it obvious , think carefully about that !
Help with DC Servo for Current Feedback Opamp klewis Chip Amps 31 4th June 2010 05:18 PM
Pots in opamp feedback networks, why not? airraid Solid State 8 5th September 2004 09:11 PM
Duplicate opamp inside feedback loop? jcarr Solid State 5 10th March 2003 10:01 AM
Page generated in 0.11799 seconds (81.77% PHP - 18.23% MySQL) with 10 queries
