Hi everybody.I made a bryston 4b-7b serie in my spare time.
![]() schematik is here : Bryston Limited - Music For A Generation Ampfilier is very sound quality but little bass. |
#2 |
arkadaşım bu amfiye neyden sinyal giriyosun bilmiyorum ama giriş empendansı 1k ohm buffer kullanmassan basslarda iyi olmaması doğal kendi şemasında önünde opamp felan var 50k ohm giriş empendansı var. çok sağlam amfi
#3 |
#4 |
My friend wrote this.He does not know english.He says to use buffer otherwise you can not get bass.
#5 |
Don't know about buffer but using PS caps will surely help.
#6 |
.....using PS caps will surely help.
the best joke i ever heard! |
#7 |
#8 |
Congratulations, it looks like quite a bit of work went into that.
I have a Bryston, the guts of it are a 2B, and the bass is very strong (into my PMC floorstanders). What you built should have at least as much bass as mine. So the circuit topology should be fine. That leaves components ? Big power supply capacitors provide energy storage for the amplifier to draw on for big bass peaks so if you've got tiny caps, which it looks like from the photo, you need more capacitance on the power supply rails.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#9 |
Umut arkadaşım.Öncelikle Burda bir turk gördüğüme öncelikle sevindim.
Opamp Preanfisi var.DOA 33 diye isimlendirmişler.Bu cihazı yaparken aynı zamanda crown xls 202 serisini yaptık.İkisini aynı beslemeyle aynı anda dinleyince bu anfi baslarda zayıf insan seslerinde çok iyi.Ancak crownda da bundaki insan sesleri yok. bu likde xls 202 serisi için Bloggang.com : K_evens : C-500 Power Amplifier |
#10 | |
Many thanks!
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
| FS: Bryston 4B NRB | akunec | Swap Meet | 0 | 12th December 2006 11:18 PM |
| Bryston 3B/4B-SST clone? | taj | Group Buys | 3 | 9th December 2006 07:46 PM |
| FS: 2 Bryston 4b's | dunderchief | Swap Meet | 1 | 14th October 2005 09:27 PM |
| Question regarding ProAc 2.5 Clone and Tempo 2 Clone | zoooh | Multi-Way | 5 | 11th March 2003 08:19 PM |
| Looking for a Bryston 4B ST clone | Phil O.son | Solid State | 5 | 6th November 2002 08:36 AM |
| Page generated in 0.11123 seconds (78.75% PHP - 21.25% MySQL) with 11 queries |
