Diy Solid state amp, designs
Old 10th December 2009, 09:11 AM   #1
highpow3rpc is offline highpow3rpc
Exclamation Diy Solid state amp, designs
Hello all i am looking for hi power amplifier designs or sites that have instructions on designing a High wattage mosfet amp either with high rail voltages or using bridgeing and parralleling of amps to drive upto 500watt @ 2ohm
Old 10th December 2009, 02:18 PM   #2
jerryo is offline jerryo  Isle of Man
I think you need to spend some time with the "search" facility on this forum as there is an enormous amount of info available for what you might be looking for.
Also try "Eliot Sound Products", which is another great site; and he has pcb's available for his design's and some very informative articles.
Have fun researching.
Jerryo
Old 10th December 2009, 02:46 PM   #3
look up Quasi's original thread. It takes you through the design development of that series of amplifiers.
regards Andrew T.
Old 10th December 2009, 06:31 PM   #4
Gordy is offline Gordy  United Kingdom
Click these...
Project 117
ESP Projects Pages - DIY Audio and Electronics
Old 10th December 2009, 06:48 PM   #5
wahab is offline wahab  Algeria
Originally Posted by Gordy View Post
Click these...
Project 117
you re putting his life at risk..!!..
highpower3rpc, be aware that high power amplifier are very risky,
i can only advice you to read and re read the procols used to
build and test those dangeourous items...
Old 11th December 2009, 10:34 AM   #6
djk is offline djk
djk's Avatar
Build project 117 with 5 pair of outputs with a 50-0-50 500VA~800VA transformer, that will get you 500W/2R.
Project 117
Candidates for the Darwin Award should not read this author.
Old 11th December 2009, 11:04 AM   #7
ratza is offline ratza  Romania
ratza's Avatar
At that power I would recommend class D instead of AB. Anyway, what are you going to do with such a thing?
Any solution is a compromise.
Old 11th December 2009, 11:33 AM   #8
a 50+50Vac 1200VA 3.5% regulation transformer with +-75mF smoothing and 6pair of MJ21193/4 should give 450W into 4r0 and 800W into 2r0 and drive a 60degree phase angle load if you can keep the heatsink (& Tc) cool.
4pair and a 700VA 4% transformer with +-45mF will give >440W into 4r0.
regards Andrew T.
Old 11th December 2009, 02:53 PM   #9
yeah i was hoping for help on finding a good class D amp
problem is i just didn't know where to start as there is so much information on this forum
Old 14th December 2009, 09:08 PM   #10
Harry Fisher is offline Harry Fisher  United Kingdom
does anyone have a board layout for project 117??
many thanks harry
Diy Solid state amp, designsHide this!Advertise here!
Solid Solid State Power Amplifier PMA Solid State 265 30th August 2011 09:04 PM
what does solid state mean exactly? cowanrg Solid State 1 30th July 2002 09:10 PM
The Solid State Wiki - Your solid state reference guide Jason Solid State 0 25th June 2002 06:26 PM
