this is my design amp.
it is 200W OUTPUT。 voltage + -70V |
#2 |
Your effort looks very nice.
How hard are you going to use it? Adcom had good success with their 60W rated 535 and 100W rated 545. They used the same circuit board for both models, just more heatsink and more outputs. The 535 had a 3.5" tall heatsink and two pair of plastic outputs. The 545 had a 5.25" tall heatsink and three pair of plastic outputs. The 200W rated 555 went to four pair of metal cased outputs with 7" tall heatsinks.
Candidates for the Darwin Award should not read this author. |
#3 |
yes 。
i will use it . this is a CLASS b amp.itis efficiency is 65%. |
#4 |
You should provide more infomation about the L20.Such as 18V/us and so on.
#5 |
Please note that only L20 blue is correct. The original provider.
It will indicate the DESIG LJM. |
#6 |
Interesting amp.
Can you please post a schematic of the latest version of the L20? Thanks. |
| 200W in 8 Ohms Class D amp wanted | Session | Class D | 5 | 8th October 2009 07:08 PM |
| SE Class A 200W PURE Heat | lineup | Solid State | 28 | 25th November 2008 07:08 PM |
| DIY 200w amp | blondfire | Solid State | 7 | 1st March 2007 10:35 AM |
| 200w Gem | serosmaness | Solid State | 0 | 30th July 2006 02:39 AM |
| My 200W/4 class AB MOSFET amp. | sparkybg | Solid State | 20 | 21st July 2005 07:39 AM |
| Page generated in 0.09392 seconds (80.79% PHP - 19.21% MySQL) with 11 queries |
