Hi All,
I'm thinking about building this circuit and using it with a valve preamp design I have sen that can supply a +/- 20v signal: Project 83 - MOSFET Power Follower Has anyone tried building one of these followers or something similar? Any comments on how it sounded? Any ideas, suggestions or improvements? I'd love to hear your thoughts. Regards, Greg. |
#2 |
distorsion is high with powermos without NFB, though this one is better
than Pass s ZEN... regards, |
#3 |
forgot to add that if you stick to 36V, it s better to drive it with a
quality OPAMP, a NE5532 would be very fine and much better than the discrete preamplifier provided you use it with no more than 20 db gain... all da best, |
#4 |
Taylor Source Follower
This is a good link about source-followers. A Taylor source-follower can give twice the current to the speaker compared to Rod Elliots project 83.
We live in a horizontal world, why use vertical topologies??? |
#5 |
#6 | |
the project about the Power Folllower but modify to a unity gain preamp with 1A idle current and only 9V supply voltage (for undistorted +/-1,5Vss, for the user the best preamp on this planet) and your suggested project, but with a sziklai modification of Parvel Macura for the upper MOSFET and 3,5A idle current by 22V supply voltage (sziklai means a current feedback pair = discrete IGBT, that content follow type: IRF510 and 2SA1216) ask Parvel Macura for schematic, because this isn't online currently. Last edited by tiefbassuebertr; 7th December 2009 at 07:44 PM. |
#7 | |
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#8 |
I did an amp several years ago using a 6SL7 as voltage amp and a very similar output stage to Pavel's follower. All distortion was low order, and the sound was indeed wonderful. If you have never heard one of these amps - or indeed the Pass Zen which was seminal too - do yourself a favour and knock one up from junk box parts.
They sound absolutely transcendental, particularly good on jazz and vocals. IMHO they tend to fall down a little with orchestral music. Hugh |
#9 |
Well said, Hugh. Still more controlled than the ZEN topology.
#10 |
The Zen was my re-introduction to electronics after a 20 year lapse.
I would never criticise it - no one does more with less than Nelson Pass. Hugh |
| anyone ever built a tube mixer similar to the RCA Living Stereo type?? | ncdrawl | Tubes / Valves | 12 | 23rd October 2008 06:13 PM |
| Does anyone has mosfet PP power follower schematic? | bogdan_borko | Solid State | 0 | 11th December 2005 08:37 PM |
| Has anybody built 6BG6 or similar OTL amp? | rnx69 | Tubes / Valves | 2 | 14th April 2004 01:25 PM |
| Driving a MOSFET power follower | RichardJones | Pass Labs | 19 | 22nd July 2002 02:02 PM |
| MOSFET Power Follower help | RichardJones | Solid State | 0 | 28th January 2002 06:01 PM |
| Page generated in 0.10513 seconds (77.59% PHP - 22.41% MySQL) with 10 queries |
