Old 6th December 2009, 08:43 PM   #1
Default Improving the HP-333A distortion analyser ?
Hello
Is anyones know any possibles improvements of those circuits or parts ; the impedance converter and the rejection amplifier/bridge balance circuits of my HP-333A distortion analyser ?
I include the HP-333A circuits images, the concerned circuits are in first two images.
Thank you
Bye
Gaetan
Old 6th December 2009, 09:18 PM   #2
Ultima Thule's Avatar
Hi Gaetan,
I don't have so much to contribute with more than that I had the same idea but with my over 20 years old scope, things I could think of is to get better transistors, especially in the scope case I think there are many more nice RF transistors these days, maybe some better capacitors and replace old dry electrolytic capacitors. Metal film resistors might be a good replacement in case of other types were used in crucial parts of the circuitry.
Did you have any list of what transistors are used or maybe you see it on the packages.
Cheers Michael
Old 6th December 2009, 09:33 PM   #3
R.I.P.
What makes you think it can be improved? My experience with the hp333A is that it's pretty much perfect as is. In what way could it be improved?
Test equipment isn't like audio, where parts choice makes it sound better - test equipment is designed for a job and it either does that job, or it doesn't. And if it doesn't, then it's faulty and can be repoaired.
And I'm talking from two points of view at once here:
1/ an ex HP service tech who has repaired 333A's
2/ an avid Upgrader and modifier of hi fi equipment.
Regards, Allen
Old 7th December 2009, 04:44 PM   #4
Hello
The HP-333A do have 80db of rejection of the fundamental frequency, is it possible to improve that ?
Thank you
Bye
Gaetan
Old 7th December 2009, 05:21 PM   #5
SY's Avatar
At discrete frequencies, yes. A twin-T notch filter will get you 20-30dB more rejection.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 7th December 2009, 09:43 PM   #6
R.I.P.
To get more than the standard 80dB notch, the notch's Q will have to be raised a LOT, which means the tuning will be FAR more critical, and drift will become an almost impossible problem.
It is what it is, and I believe any attempts to "improve it" will just screw it up.
It was designed for normal audio usage, not a research project into ultra low distortion levels.
But it can be VERY useful as a front end for a 24 bit computer based spectrum analyser system, the 333A's notch will allow the computer to have a far deeper look into the harmonics. And allow convenient gain changing/attenuation, things often very hard to arrange with a regular sound card and software.
Regards, Allen
FS: HP 333A Distortion Analyzer and 204C Generator jon_010101 Swap Meet 0 5th December 2009 04:46 PM
Distortion analyser circuit steevo Solid State 12 21st July 2008 01:42 AM
IM Distortion Analyser Alain Dupont Parts 2 6th January 2005 02:48 AM
HP334A Distortion Analyser Netlist Swap Meet 1 14th October 2003 10:33 PM
HP333A Distortion Analyser Netlist Equipment & Tools 12 13th October 2003 09:40 PM
Page generated in 0.09148 seconds (72.64% PHP - 27.36% MySQL) with 11 queries
