Old 4th December 2009, 11:25 PM   #1
Default Adcom GFA 555 amp - Troubleshooting Q
I seem to have lost the 'right side speaker' of the amp. The speaker is fine and plays fine when I plug it into the left side. Does a second fuse exist for the right or left side in the unit?
Thoughts on trouble shooting this?
Old 5th December 2009, 12:33 AM   #2
Default GFA 555 amp - 6 amp 125 volt fuse
Local radio shack doesn't carry these little 6 amp 125 volt fuses. They carry 6amp 250 ? I assume I need the 6 amp 125. Sorry, I've never had to take one of these apart. Suggestions on location to purchase these?
Old 5th December 2009, 12:34 AM   #3
I believe I have this figured out..Need to figure out which fuse. I pulled out 6amp 125 volt. Radio shack doesn't carry these...they carry 6amp 250's. Thoughts? If not, where to get the 6amp 125's...should they be slow blow?
Old 5th December 2009, 12:49 AM   #4
Iain McNeill's Avatar
The voltage rating isn't important as long as the fuse fits in the holder (right size) If you look at the blown fuse it should say either 6AF or 6AT. F is fast, T is time delay (sloblo)
If in doubt, use a fast.
Of course, you need to fix the problem that caused the fuse to blow first
...and I merged your two threads.
Old 5th December 2009, 01:03 AM   #5
Thanks for merging my two threads. The time delay thread approval has me thrown for a loop.
So, a 6 amp 250 watt is a fine replacement for a 6 amp 125 volt? the markings are BEL 3AG 6A125V
Old 5th December 2009, 11:35 PM   #6
kirk57 is offline kirk57  United States
Yes you can use the 6A 250 volt fuse instead.
Now as to why it blew....did you do something (like moving cables around while blasting music) that may have caused a problem resulting in the blown fuse?
Adcom GFA-555 - Need troubleshooting assistance. randar Solid State 9 29th March 2009 10:00 PM
NAD 705 Troubleshooting jocko_nc Solid State 6 15th July 2006 08:23 PM
troubleshooting my new dac DaKi][er Digital Source 25 18th July 2005 09:00 AM
JVC JA-S55 amp troubleshooting 80sJunior Solid State 0 20th January 2005 07:26 AM
Adcom GFA-585 went bad - calling Adcom experts hangguy Solid State 14 24th December 2004 08:09 PM
Page generated in 0.10543 seconds (76.78% PHP - 23.22% MySQL) with 10 queries
