Old 4th December 2009, 05:48 PM   #1
Default Microphone self-noise
Would self-noise and noise picked up a microphone coil be common mode or not?
Want to build a mic pre directly onto a dynamic capsule -- can't figure if a differential front-end would be an advantage in the total absence of any cable.
Thanks.
Old 4th December 2009, 08:16 PM   #2
SY's Avatar
It won't help the self noise; that's a consequence of the physics of the transducer. But since you're eliminating the leads, it will prevent common-mode noise pickup from that source. There still might be an advantage to running the output of the preamp balanced, minimizing common-mode noise pickup further down the chain.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 5th December 2009, 11:06 PM   #3
The term 'common mode' refers to transmission lines not devices.
Old 5th December 2009, 11:44 PM   #4
MEGA-amp's Avatar
Common-Mode Signals Defined:
When referenced to the local common or ground, a common-mode signal appears on both lines of a 2-wire cable, in-phase and with equal amplitudes. Clearly, a common-mode signal cannot be present if one of the lines is connected to local common. Technically, a common-mode voltage is one-half the vector sum of the voltages from each conductor of a balanced circuit to local ground or common. Such signals can arise from one or more of the following sources:
* Radiated signals coupled equally to both lines,
* An offset from signal common created in the driver circuit, or
* A ground differential between the transmitting and receiving locations.
Old 8th December 2009, 01:13 PM   #5
@ toddboyle; Perhaps I've misused the terminology
Although MEGA-amp's statement here appears not to agree:
Originally Posted by MEGA-amp View Post
Such signals can arise from...
(my emphasis)
Probably my qustion would have been phrased better as:
"what percantage of the noise eliminated by the common mode rejection of a balanced microphone preamp originates in the microphone capsule rather than being contributed by the cable?"
Anyway, Sy appears to have understood what I was getting at.
So an unbalanced single-ended mic pre won't be outperformed by a more complicated balanced design in this instance. That will make my life easier.
Yup, since I'm planning to use this thing onstage balanced line output on XLR will be mandatory. SSM2142 or DRV134 look right, are available to me, and should be easy enough to wire up.
Low noise transistor and noise figure Real_Macgyver Solid State 26 31st January 2011 01:34 PM
Low Noise Balanced Microphone Preamp (PCB also). Ayne Solid State 11 22nd April 2007 03:46 PM
Need microphone amp borges Analogue Source 0 1st June 2005 10:52 AM
spy microphone sss Everything Else 10 6th January 2005 11:00 AM
Noise cancelling microphone? sobazz Everything Else 7 17th April 2004 07:56 PM
Page generated in 0.08207 seconds (73.74% PHP - 26.26% MySQL) with 11 queries
