Hi, I am new to this forum and I am not particularly knowledgable on electronics but trying hard to get a grasp. I have owned an Aura VA100 and the TU80 for many years and had a lot of satisfaction from them. I am reasonably happy with the VA100 but have recently started to use the phono stage with a new Systemdek turntable I have acquired. The phono when first used sounded good but after approximately 3 minutes the right channel died. I have swapped the stylus feeds around and I am happy the problem lies in the amp which either refuses to run on the right channel or if it does it lasts only for approximately 2 to3 minutes after start up. It is almost as if a unit is heating up and once warm fails. Can anyone point me in the right direction for identifying the possible problem?
I note the previous threads on this amplifier and would be grateful if somone could advise if there are any standard simple upgrades that can be made to improve the unit - that is not to say I am dis-satisfied with its current perfomance as it does appear to me (an admittted novice) to be a reasonably good amplifier but if there are any simple upgrades then I would be tempted to try to improve on the sound. Does anyone have an opinion on the quality of this phono stage which Aura claimed was very good - but there again they would. Jak |
| Aura Evolution VA100 • Clean up & upgrade | Malefoda | Solid State | 85 | 13th May 2012 08:14 PM |
| Aura Va100 Evoluton Ii | ANALOG GUY | Solid State | 31 | 25th February 2012 01:46 PM |
| Aura AUC-50 (Philips CDM-9) CD reading problem | ceharden | Digital Source | 3 | 16th April 2009 08:29 PM |
| DIY phono to replace roksan phono stage | seroxatmad | Analog Line Level | 6 | 14th December 2008 05:46 PM |
| Should I replace Scott 222C phono stage with Claret phono stage? | Bing Yang | Analogue Source | 0 | 22nd August 2005 06:41 AM |
| Page generated in 0.07018 seconds (67.27% PHP - 32.73% MySQL) with 10 queries |
