I am proud to announce the Dx-M, 300 wiskies of power with a very low distortion
Old 3rd December 2009, 05:44 PM   #21
Ultima Thule is offline Ultima Thule  Europe
Ultima Thule's Avatar
Carlos I agree with Bigun, don't give up yet, you have added many new things in that design, one part of DIY is to study each part of the circuit and make some small research here and there, right?
You could for instance try without the current mirror, and then you could instead of CCS loading drivers try just a simple resistor between the emitters of MJE340/350, and there are certainly many other interesting tweaks you could try out.
Go back a couple of steps so we don't have too many new feature at once which will just make up to the confusion.
You will get the inspiration from us, don't worry!
Cheers Michael
Old 3rd December 2009, 08:05 PM   #22
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Have dismounted and used parts to produce a standard
to be tested under 80 volts... and the standard, as usual, worked fine.
I do not know bigun... sounded alike the Precision 1 .... no way to have two amplifiers sounding the same.... i have not evoluted and my health problems are impeachment to go insisting for too long.... this will ruine my circulation..no way.
Have not worked the way i want, after 3 hours tweaking i use to give a shot on them...this case i have made the Standard to be tested, as TAJ is interested and i wanted to know (scope) if there's something strange.
Nothing strange, nice sonics.... subject finished.
The picture is the Dx Standard customized to TAJ, he wants to use his 70 volts power transformers.
Let this thread die dear Bigun...next amplifier will be Dx Best!.... not this time.
a big hug to you...till the next amplifier dear Bigun.
regards,
Carlos
Old 3rd December 2009, 09:34 PM   #23
Bigun is offline Bigun  Canada
Bigun's Avatar
We Trust in the guru and look forward to the next
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 3rd December 2009, 11:24 PM   #24
ostripper is offline ostripper  United States
ostripper's Avatar
I found unstabilities, then the CCS was removed and the traditional circuit was assembled in place... sound stérile...then i have removed the CCS to drivers, result much better...well.... finally, resulted alike Precision 1
I wonder why ??? MJE340/50 driving 5 pair 21193/4's ??? Hmmmm... current sources 10 times more Ic than main drivers , lucky no you give up way to easy ! Build the mje340/50 - 21193/4 - 21193/4 triple with mje15032/3 or Tip (XX) current sources and it WILL work (Attached).
Edit : D5/6 = red led with 1.6-1.8v drop , 4 diodes would work ,too.
OS
Old 4th December 2009, 04:14 AM   #25
Default I have not health conditions to insist too many hours into an amplifier
When i found it sounding alike the Precision 1 i give up, because i think it is non sense to me to produce another one alike in sonics.
But maybe, if you are interested, you can develop the amplifier to suit your needs and beliefs.
My legs and feet gonna inflated by bad blood circulation, i had pains into the legs....no condition to me to go sitted for many hours anymore.
Enjoy the amplifier, and try a CCS, this way maybe will sound different compared to others..and this will be an advance to forum, giving them several options of sonics.
CCS to drivers use to produce a nice sound, in special punch into the bass low end... electrocompaniet did it a long time ago.
never mind and be happy,
regards,
Carlos
Old 4th December 2009, 12:08 PM   #26
Default I have tested this one, made for Taj and Sound buster
as both of them told me they have the 70 volts transformers.
This one was tested, but, as drivers i have used 2SC4793 and 2SA1837, and as VAS i have used 2SC4793.
Into the differential i am using BC556C, and this because my supply have voltage drops...better to use 2N5401 as shown into the schematic.
Working fine, sounding great, very stable, pumping high power (more than 300 watts in 4 ohms)... waveform fine and TESTED!
regards
Carlos
Old 4th December 2009, 12:36 PM   #27
black is offline black  Romania
Send a message via ICQ to black Send a message via AIM to black Send a message via MSN to black Send a message via Yahoo to black
posting youtube testing the power and sonics
Old 4th December 2009, 12:42 PM   #28
Default Yeah!...i love do that....problem is the digital camera that does not register high
frequencies...so, the sonics are always poor into youtube.
Also i cannot increase volume, the camera saturates..but, i will try something.
Today will be listening.... i will manage to do something about.
regards,
Carlos
Old 4th December 2009, 12:51 PM   #29
thanks carlos weithing
Old 4th December 2009, 04:45 PM   #30
Default Here you have a sample dear Black...not so good
I think my camera is damaged..in the past used to make better audio recordings, maybe the microphone is damaged.
YouTube - Dx custom Taj and Soundbuster.avi
regards,
Carlos
I am proud to announce the Dx-M, 300 wiskies of power with a very low distortionHide this!Advertise here!
another reason to be proud... tomtt The Lounge 26 9th February 2016 04:33 AM
I will be the proud papa of a Super T amp 3-LockBox Class D 1 12th June 2006 11:49 AM
Proud new owner of 4ch LM3875 quickshift Chip Amps 2 18th August 2005 06:41 PM
Proud owner of a new GC amisdad Chip Amps 3 18th October 2004 06:11 PM
New proud owner of Aleph 5 bbakota2000 Pass Labs 28 23rd April 2004 12:30 PM
