As replacment of 2sa1142P in my Denon PMA1560 AMP they have give me
2sa1546 from NEC 2SA1546 pdf, 2SA1546 description, 2SA1546 datasheets, 2SA1546 view ::: ALLDATASHEET ::: Vceo is a bit higher, a1142 =180V a1546 = 250V Can i use this 2sa1546 as a good replacement without any danger problems. Regards Rick... |
#2 |
yes, it should work , provided it s well cooled, as the TDP is
7W rather than 10W in the original part.. |
#3 |
Hi wahab, thnks for your information.
It`s not possible to use it without any heatsink i understand, or is it possible. Do you think that will be a big problem? Because there is not such much place for a heatsink. |
#4 |
as i understand, it s not fixed on a heatspreader...
even so, the original did surely fail because it wasnt cooled.. since there s a hole on this trans. , you can surely fix a little piece of metal, a few cm2, so it will be at a significantly lower temperature...an aluminium plate of 2 X 3 cm should be enough... |
#5 |
hello WaHab,
Do you think this is ok now at this moment. There was not many space, but ok, I hope this will work. Only had to move 3 resistors to the backside, but i don`t think that is a problem. ![]() Regards Rick... Last edited by rick_noname; 1st December 2009 at 09:12 PM. |
#6 |
[QUOTE=rick_noname;1998643]hello WaHab,
Do you think this is ok now at this moment. There was not many space, but ok, I hope this will work. Only had to move 3 resistors to the backside, but i don`t think that is a problem. ![]() Regards Rick...[/QUOT perfect....i couldn t have make it better.. hope you now enjoy your denon PMA...very good amp,, anyway... |
#7 |
Ok thnks, i`am happy with it.
It`s a lot of work. I have replaced all TR positions on the left and right amp. Also all diodes and burned resitors. In the whole amp i replaced all electrolytes and renewed all solder points. It was a hard way to find a lot of originals components. Bigred from Diyaudio had send me 3 matched pairs of 2sk184gr. so everything is completed now. also original new op-amps. So for now de last litle things and then i hooooooooooooope it will works like a new one ![]() Maybe, you have also some tips for this amplifier. Thnks for your help. regards Rick... |
| Replacement for CDM 12.1 | Sandor | Digital Source | 4 | 12th June 2010 08:01 PM |
| Old Amp Pot Replacement | DeadSpeaker | Solid State | 0 | 10th December 2008 09:39 PM |
| Another cap replacement: uF changes.. | cuibono | Tubes / Valves | 8 | 6th November 2007 08:06 PM |
| looking for a replacement for pcb cad | bigpanda | Solid State | 1 | 18th September 2004 07:24 AM |
| Replacement for 5R4 | Ralph | Tubes / Valves | 8 | 16th December 2003 10:02 AM |
| Page generated in 0.09857 seconds (72.19% PHP - 27.81% MySQL) with 10 queries |
