Old 29th November 2009, 09:22 PM   #1
Default Disimproved NAD 304
My old NAD 304 used to have the famous channel fading problem. So tried to replace the R 334 as recommended in many threads. But instead of using a 47k resistor, I accidently used a 47r resistor... Well, that's a factor of 1000. Since then, the red LED does no switch to green anymore. I replaced the resistor and put in a proper one, but the problem persists. So I think I burnt some other components. As I am rather new to electronics, I would be really grateful for any advice on where to start looking.
Old 30th November 2009, 04:43 AM   #2
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
Check Zeners D306 and D308 (I think that's the numbers as the copy of the service manual I have i rathter poor quality). There should be 3.9V across each.
My copy of the manual can be found here:
Welcome to Audio Circuit Denmark
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com
Old 30th November 2009, 10:04 AM   #3
Thanks for the quick reply. I'll give it a try post the results.
Old 30th November 2009, 11:01 PM   #4
CrazzyAbtTubes's Avatar
While you are at it, you should check for bad solder joints, they are almost always the cause of intermittent problems.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 33.33%)
Copyright ©1999-2013 diyAudio
