I am intrested in building a clone to the Audioinics CC-2 amp,I owned the amp a few years back,but it was stolen,and I still have the schematic,These driver transistors are hard to find,and the NTE replacements are a little on the pricey side!! any suggestions?
#2 |
MPSW06/56.
These are MPSU06/56 without the metal tab. MPSA06/56 are the 600mW version, the 'W' are the 1W version. The 'U' were able to handle 1.5W with a small heatsink. You might also look at the MJE243/253.
Candidates for the Darwin Award should not read this author. Last edited by djk; 28th November 2009 at 02:46 PM. |
#3 | |
The schematic shows the drivers running in parallel,Three each, I believe w/o heatsinks,so I guess the 600mW versions would probably work? I checked out the data sheet on the 243/253,virtually identical parameters,with the exception of higher wattage,but lower bandwidth. Last edited by denny9167; 28th November 2009 at 06:46 PM. |
#4 |
the drivers were parralele because at the time, they didn t have
such transistors with a 5W rating and with a high ft, in the order of 60MHZ...with one driver, the amp used to blow up as soon as the load was somewhat reactive....currently, you can use recent drivers like the audio pair 2SA968/2SC2238 with a 25 wtt rating, one is enough.... for the output power stage, you can also use more recent bjt, the like of 2SC5200/2SA1943...surely, the compensation network must be lightly tweaked, otherwise, this topology is a must and is still up to date...in fact, i never heard something better, unless it was the same but with mosfet in the power stage... |
| Replacements for LM383 | soundNERD | Chip Amps | 9 | 19th October 2010 04:26 AM |
| Capacitor replacements | dognut | Parts | 2 | 26th March 2009 12:57 AM |
| 2sd1213 replacements | shagone | Car Audio | 2 | 28th May 2008 12:45 AM |
| replacements | doktor | Solid State | 8 | 10th March 2008 12:11 PM |
| RAYT7649 IC replacements | mmerig | Parts | 4 | 21st March 2006 06:09 PM |
