Continuing on my list of stupid questions regarding instrumentation applications...
When designing an AC-coupled output driver that needs to work in a balanced as well as unbalanced mode (ie, occasionally one output will be tied to ~ground or more likely the output impedances of the two legs will be unequal), is it sufficient to simply use two buffers with complementary inputs and thus complementary outputs or would that result in an output that's attenuated by 6dB when one output is tied to ground? Or would one use a servo output to compensate for the AC impedance of one half being taken to near zero ohms? Thanks in advance!
"My name's Monty, and I break things." "Hello, Monty!" |
#2 |
The answer is "yes. The servo is required to prevent attenuation or other weird effects on [severe] impedance mismatch" which is what I thought.
...so why is it usually called a DC servo when it appears that the real value is coupling AC mismatches into the feedback not DC?
| unbalanced stereo out to mono summed balanced output | Original Burnedfingers | Solid State | 3 | 11th January 2009 05:45 PM |
| D1 I/V, balanced dac, unbalanced output | 00940 | Pass Labs | 2 | 30th April 2005 12:12 AM |
| unbalanced/balanced/unbalanced conversion using transformers | vladimir | Solid State | 10 | 27th February 2003 06:54 PM |
| Zen Balanced Line Stage Balanced vs Unbalanced | macka | Pass Labs | 28 | 11th December 2002 06:18 AM |
| What are the correct output line levels for unbalanced & balanced? | Brian Guralnick | Digital Source | 4 | 25th October 2002 06:27 PM |
| Page generated in 0.07174 seconds (69.20% PHP - 30.80% MySQL) with 10 queries |
