Beware!!!!! Fake Sankens - diyAudio
Old 24th May 2003, 07:04 AM   #1
mcp is offline mcp  United States
Default Beware!!!!! Fake Sankens
This is a much sought after part from Sanken. One is an original, the other a FAKE. The complementary part 2SC2922 looks very close like the original too. Information on how to tell them apart can be found at
http://www.ampslab.com/projects.htm
Mike
Michael Chua
Old 24th May 2003, 10:57 AM   #2
Piersma is online now Piersma  Netherlands
Piersma's Avatar
Default FAKE
Micheal,
I have taken a look of some 2SA/SC transistors on my shelf and i noticed the following. The lettering "SANKEN" seems original to me but the production run number is in the middle.
I am confused, are they fake or not ?
Greetings from Holland
Piersma
Old 24th May 2003, 11:17 AM   #3
Banned
Send a message via Yahoo to Elso Kwak
Default Re: FAKE
Originally posted by Piersma
Micheal,
Piersma
Hi, Yes I am extremely confused too. Maybe they are both real!
Below a picture from www.schuro.de that I believe is the genuine article. Mike do you have measurements or listening tests to prove which one is real?
Old 24th May 2003, 11:24 AM   #4
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
What about those?
They are the original transistors from an old Crest 5000.
/Hugo
Old 24th May 2003, 12:35 PM   #5
Hi everyone,
The one on the right is the real one.
Piersma, Elso....look like your Sankens are OK . If you have the time, check out my site or Rod's. The visual differences are explained more in detail.
orginally posted by Elso
I don't need to. Let's just put it as "supplier & customer confidentiality". If you like to know more, drop me a mail.
What about those?
/Hugo
I can only verify 2sc2922 and 2sa1216. The ones in the Crest should be real. One of the main difference between a fake and an original is the inability to supply the same power output. The frightening part is this particular fakes look like real.
Michael Chua
Old 24th May 2003, 02:43 PM   #6
JojoD818's Avatar
hi all!
here in my country a shop sells both originals and fakes! fakes for about $0.80 and the orig for $4.50, their reason? some people want to buy cheap ones because the origs are very expensive. But if your amp blows up while using the fakes, the store will not be liable she said.
jojo
Old 30th May 2003, 01:39 PM   #7
Default Inside view
I finally cracked open the fake Sanken and compare it to an original. The differences are quite astounding. You can see them at:
Michael Chua
Old 30th May 2003, 02:59 PM   #8
grataku is offline grataku  United States
Originally posted by Netlist
What about those?
/Hugo
Yes, those are the real ones. It's not really hard to tell, come on.
The forgerer had to give it away by using NY as the selection code.
Old 30th May 2003, 03:04 PM   #9
Banned
Arrow Re: Inside view
Hi Michael,
I am sorry but my gutsfeeling tells me it is the other way around.
I feel the transistor with the die directly attached to the collector case is the real one and the one with the TO-220 case attached to the larger plate is fake.
Maybe others know more about the inwards of transistors.
Please be careful, wash your hands!
You might be exposed to Berylium that is highly toxic.
Old 30th May 2003, 03:29 PM   #10
Elso,
In fact, they are probably both fakes! The selection code is not convincing (i.e. the 1 number and 2 letters) but most of all the weight doesn't match the weight indicated on the datasheet that is ~18 grams.
Beware of big bass sam9 Everything Else 1 4th September 2004 04:49 AM
Copyright 1999-2017 diyAudio
