PC simulation - what do you use?
Old 24th November 2009, 05:50 AM   #1
akis is offline akis  United Kingdom
Default PC simulation - what do you use?
What is the 2009 recommended simulation program? I have used Multisim 10 Educational, it is slow, cumbersome, impossible to use over 300Hz, no support for European transistors, I do not like how it models transistors anyway and so on. Is there anything better?
An associated thread is here Simulation software.
but it is quite old.
Old 24th November 2009, 06:23 AM   #2
OK, just looked at LTSpice. Compared to Multisim, the interface looks like something out of the 1980s. Have only spent like 15mins on it, seems to have a good array of models, but I could not find an oscilloscope or other instruments. Instead it plots Voltage/Current charts, which I could not interpret. And the user interface sucks.
Old 24th November 2009, 06:34 AM   #3
sawreyrw is offline sawreyrw  United States
LTspice is the best. It's simple to use and does everything an expensive SPICE package does. Read the help file and try a little harder.
Old 24th November 2009, 06:46 AM   #4
OK here goes. :-)
Old 24th November 2009, 09:24 AM   #5
nelsonvandal is offline nelsonvandal  Sweden
nelsonvandal's Avatar
This is the problem. The users are expected to try a little harder, not the designers. It should be the opposite.
Old 24th November 2009, 10:14 AM   #6
derwhalfisch is offline derwhalfisch  New Zealand
This is true, but once you figure LTSpice out, it's rather simple (in my limited experience) to get it to work. Just takes that initial figuring out ;P
Old 24th November 2009, 02:20 PM   #7
I have tried again. I have managed to place a few components (9 resistors, 3 transistors, couple of caps, two sources) and have managed to see some graphs of sinusoidals.
Basically LTspice runs the analysis for a period of time, then you can go back and see what happened by probing the circuit, looking at the graph, selecting a time range and expanding it appropriately so you can see the curve rather than a blob.
But I cannot get to work with that GUI with placing and re-arranging components. It is awful. It is like using MS Paint to draw delicate pictures and graphs.
Mutlisim also has some other cool features : range of instruments, eg oscilloscope, function generator, distortion analyser, potentiometer, varcap etc.
Perhaps Mutlisim Pro is better than Multisim Educational?
Old 24th November 2009, 02:45 PM   #8
Ouroboros is offline Ouroboros  England
Ouroboros's Avatar
At work I use the industrial version of TINA-8, and use the basic version (€79) at home. TINA doesn't give you the control that LT Spice gives, but it does have a proper UI, rather than the user-hostile experience you get with LT-Spice.
If you don't want to risk €79, then download the free (but very tool and model limited) version of TINA from the Texas Instruments website. Otherwise go to Analog, Digital, Symbolic, RF, VHDL, MCU Circuit Simulation & PCB Design
Old 24th November 2009, 03:57 PM   #9
cbdb is offline cbdb  Canada
LTSpice will also do all those things and more , just have to figure out how to do them. There used to be a LTSpice thread on this site, where you could always get answers, or go to LTSpice users group at yahoo.
Old 24th November 2009, 04:16 PM   #10
Bigun is offline Bigun  Canada
Bigun's Avatar
You get what you pay for applies here.
LTspice is a popular tool for users of this forum from what I can see so it does have the benefit that there are a number of experts around and you can post files for others to use. Because of it's popularity there is a lot more knowledge of it's pitfalls too.
I got used to the interface but it really could benefit from a better one.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
PC simulation - what do you use?Hide this!Advertise here!
IV Simulation Question PigletsDad Digital Source 1 7th April 2008 12:41 PM
Need some help with simulation guitvinny Tubes / Valves 4 12th January 2008 12:33 AM
OB simulation augerpro Multi-Way 10 4th June 2007 12:17 AM
Simulation software. beppe61 Solid State 30 28th February 2006 08:19 PM
Need help with simulation Fuling Solid State 10 19th December 2003 07:44 PM
