Hi everyone,
I'd like to ask for advice regarding my broken subwoofer plate amp - which [unfairly :-) ] is just not working! The fault comes after modding by adding 4x10,000uf caps, each of which was wired in parallel to an original corresponding 4,700uf cap. The fault is this: Power comes on, controls seem to work ok i.e. turning up the volume increases noise from the drive unit. However, the signal from the hi *or* low-level input doesn't seem to be getting through. I am convinced the fault is not specifically with my caps, but with something I've knocked or somehow upset - I just don't know what! Has anyone else had a similar problem, or any clue as to what might be causing this? Thanks, Simon ps - I can post pictures of the boards if anyone would like |
#2 |
See if the diodes or rectifier bridges are not burned with the stress ...from the dramatic increase of filter capacitance...
regards
Jorge |
#3 |
I would say check the bridges first, but so far in my experience blown bridges resulted in blow fuses as well, So check fuses too.
Nice avatar, BTW
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#4 |
Thanks for the suggestions, I will check all around for blown components, certainly tomorrow - it's 3.30am here
![]() However, can we assume for now nothing has blown or melted, as I'm fairly sure everything *looks* fine? Also, and I should have said this originally, but a few days before this mod I put in a 22nf film cap across each 4,700uf original, and I had exactly the same problem after doing that. The only difference was...I disconnected and left the pre-amp board out, went to bed, and reconnected it the next day, and it worked!!! This time though, no joy, no nothing... at least below ~50hz ![]() I have put a multimeter across the caps after disconnecting the power, and they have power stored in them, I don't know if this helps - to be honest, I'm a beginner with this type of mod! -Simon ps - I'm glad you like the avatar Peter, I was actually thinking of losing it - 'cause it looks so weird! Those caps there are 8uf 600v LCR (iirc), and they sound lovely
#5 |
If you have voltage across the caps it means that bridges are fine. And if increasing volume brings more noise it seems like output stage is working too. What about your source, or connection between source and amp. Is it working fine?
#6 |
Connection to it is definately fine, I've tried one or both channels of hi-level and even connected the ends to a normal speaker - it was fine of course. I also tried the low-level from the LFE channel on my AV amp.
All the connectors seem fine also, before taking them off the 1st time I marked them with an indellible pen to be sure of putting them back right. It seems as if the problem is the connection somewhere between the input board and the pre-amp board, *or* some kind of protection circuit, or something! |
#7 | |
#8 |
Thanks again, that's an idea I will try tomorrow. Just for fun, I suppose, here is a pic of the 'power amp' board, with the pre-amp board not connected.
-Simon |
| Amp non working | covik | Solid State | 0 | 12th November 2006 09:12 PM |
| WTB Krell KSA Mk2- working or non working | Jozua | Swap Meet | 0 | 20th March 2006 12:14 PM |
| sub amp not working | felzi | Chip Amps | 0 | 28th July 2005 06:29 AM |
| p3a not working, help! | benmanf | Solid State | 9 | 27th May 2005 02:02 PM |
| Page generated in 0.09090 seconds (86.05% PHP - 13.95% MySQL) with 11 queries |
