diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   Bargraph and clip LED's (http://www.diyaudio.com/forums/solid-state/155571-bargraph-clip-leds.html)
nigelwright7557 24th November 2009 12:42 AM
I see very little of clip LED's and bargraphs on this audio group.
I would have thought a clip LED was vital if your speakers arent to suffer.
A bargraph top LED can also act as a clip LED.
Just finished a new design which uses a PIC microcontroller to read the output signal and convert it to a bargraph display. The PIC has A2D inputs so I can compare the output signal to the supply rail to get the correct ratio for the LED outputs. My clip LEd circuit uses a simple comparator taht turns on the LED as the output voltage approaches the rail, works a treat and with very few components.
A bargraph brings the amp to life.
Copyright 1999-2017 diyAudio
