#11 |
Another concern might be levels. Pro balanced interfaces run 14 db hotter them consumer unbalanced ones. I dont know the DCX or what levels it uses.
#12 |
Unfortunately, it is hard to find unbalanced equipment of this type. Many people have used the DCX in the same way as I am to control multiple subs. I have read one or two complaints about the extra gain that the DCX adds, but most seem to find that it works fine. This shouldn't be an issue for me since I can control the sub out level on the receiver as well as output levels on the DCX. There is a moderate impedance mismatch between my receiver sub output (1.2k ohms) and the DCX analog inputs (22k ohms). So, using a transformer on the input might not be such a bad idea. The commercial ones are a bit pricey, though, and I'm a bit concerned about low frequency losses with those. The output impedance of the DCX (160 ohms) and input impedance of the amps (rated only as "up to 600 ohms") are in the same ball park.
I have pretty much decided to keep the signal ground separate form the chassis ground on the amps at this point. If I run into issues I can always connect them, and rewire the interconnects, if necessary. - Doug |
| ~14 VDC between chassis ground and signal ground... | StalfoS | Chip Amps | 3 | 5th May 2007 08:26 PM |
| signal wiring / chassis grounding - Aikido | cbutterworth | Tubes / Valves | 0 | 7th December 2006 04:18 PM |
| signal ground and earth ground | ttray321 | Tubes / Valves | 9 | 3rd May 2005 03:14 AM |
| Chassis Ground = Circuit Ground --> Problems? | rhildenbrand | Pass Labs | 5 | 23rd April 2004 01:08 AM |
| Should I directly connect my signal ground to chassis ground? | Bricolo | Solid State | 3 | 28th February 2003 05:31 PM |
| Page generated in 0.07040 seconds (64.98% PHP - 35.02% MySQL) with 10 queries |
