Old 20th November 2009, 04:34 PM   #1
deltavektor's Avatar
Default Intel CPU heatsinks as power output transistor heatsinks?
Whats the opinion here about recycling redundant cylindrical INTEL CPU heatsinks in DIY amplifiers?
I love the shape of these heatsinks and think they will look funky mounted on top of the enclosure. One can even use the fan to aid cooling.
Each output device can have its own heatsink.
Old 20th November 2009, 04:49 PM   #2
Spiny is online now Spiny  United Kingdom
Spiny's Avatar
With a fan these can dissipate around 100 watts but its a bit noisy
Without a fan they are not very efficent as the fin size and spacing are designed for forced air cooling.
I have used similar aluminium ones (with fan) for an adjustable PSU with 3055's bolted to the sinks, Uses a temp. sensor to drive the fan to keep the noise down been reliably in use for many years.
Also been used for lowpower chipamps (5/12 watt channel) without fans, Handy source of cheap heatsinks
Old 20th November 2009, 10:26 PM   #3
nigelwright7557's Avatar
They tend to be a bit too small for my amps, I usually go for 600watts plus.
I do use PC cases tho for their mountings for fans and mains sockets etc.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 20th November 2009, 10:27 PM   #4
Spiny is correct.
One way to minimize the fan noise is to come up with a circuit that will start the fan, then drop the voltage to keep it just barely turning. Most 12V fans will stay running with as little as 5V, and will be practically inaudible. Then use the temp sesnsor to ramp up the fan as needed.
Old 29th November 2009, 02:47 PM   #5
godfrey is offline godfrey  South Africa
Hi deltavektor
If you've got a spare copper-core, I'd be interested in recycling it into my PC.
(if you're anywhere near Cape Town, that is)
</OT>
These Intel HSF's have a built-in speed-controller, hence the 4 wires: +12V, earth, control and speed-sense. I forget exactly what the control signal looks like, but I think it's something you could generate quite easily with a 555.
Cheers - Godfrey
MANY & BIG & NEW High-power black anodized extruded aluminium HEATSINKS for sale cocolino Swap Meet 18 5th December 2006 08:39 AM
FS: Aleph 3 Power supply parts, caps, toroid and heatsinks vsr123 Swap Meet 4 20th March 2005 11:40 PM
power transistor output capacitance hienrich Solid State 3 26th December 2004 08:18 AM
Large Heatsinks anyone (probably suit a high power or class a amp) Rixsta Pass Labs 19 20th May 2004 10:22 AM
heatsinks for power follower fezz Solid State 1 9th March 2002 12:15 PM
Page generated in 0.09900 seconds (73.95% PHP - 26.05% MySQL) with 10 queries
