Hola Y'all,
My question is there a quick test to check a zener diode to see if its good or bad?? I checked a new one and it measured open in one direction and several meg ohm in the other direction and the zener in question read ~75 ohm in both directions which I suspect is bad. Your comments are welcome. Regards, Elwood
"when you open your mind to the imposible, soon you will find the truth...." |
#2 |
Most 'Zener' diodes are in practice several avalanche diodes in series - how many depends on the voltage rating.
So both the forward and reverse voltage drop may be larger than an ordinary digital avo-meter is designed to cope with. Some old moving coil meters are better at this since they use a rather high voltage battery (some up to 15 or 22V)
Steerpike's Toybox |
#3 |
Should read as a normal diode when forward biased... ie on the diode range on a DVM it will read 0.7 ish meaning 700 mv dropped. 'tother way about and it shouldn't read as general rule for anything over a couple of volts or more but that's useless for testing accurately.
All you need is a battery of higher voltage than the zener and a restor to limit the current. Choose resistor as follows (or even better use a FET as a constant current source) R= (Vbatt-VZener)/0.010 and measure the voltage across the zener and see if it agrees with the device in question. Oh yes
#4 |
Only some 'zeners'. Not if it is a compound device, which many are.
#5 |
Thanks a heap you guys I guess I'll get the soldering iron out and solder and test.
Thanks again, Elwood
#6 |
Just a quick update... replaced zener along with several trannies and my amp turns on, somewhere in this conglomeration of threads there is my B2 thread meet me there...
| zener diode question | mike49504 | Car Audio | 2 | 2nd September 2007 07:17 AM |
| Quicksilver zener diode mod | newears | Tubes / Valves | 19 | 31st December 2004 11:41 PM |
| regulated PS - with Zener diode | ErikdeBest | Tubes / Valves | 11 | 30th June 2004 10:48 AM |
| Zener diode indentification! | bbakota2000 | Parts | 2 | 23rd March 2004 12:55 AM |
| W054 Zener diode, what is it? | Andypairo | Parts | 5 | 25th December 2003 05:31 PM |
| Page generated in 0.07988 seconds (77.25% PHP - 22.75% MySQL) with 10 queries |
