Can oscillation destroy output transistors? - Page 2 - diyAudio
Old 13th June 2003, 12:32 AM   #11
TonyTecson's Avatar
jojo,
it is possible to have oscillation problems in an amp specially with a common emmiter type output stage, if you are fammiliar with the "kinetic" amps sold locally, these amps are notoriuosly prone to such oscillations...so that whenever i am asked to repair one, i politely turn down unless i can change the output stage...Ft is the gain bandwith rating of a power transistor, it is when the small signal gain of the transistor reaches unity at a maxed frequency, it is common for power transistors to have ft's of 2-4mhz while small signal transistors have 100-up mhz....i use 10ohm 1 watt resistors as fuses when testing amps, you know by now how fast you can loose your power transistors with a slight mistake such as a reversed bias diodes.....cheers...
How to destroy your high-end audio equipment... HaflerFreak Solid State 109 27th May 2011 07:04 PM
Best way to destroy a Subwoofer boxcustom Car Audio 56 17th July 2008 06:01 PM
Long output lead or long output transistors leads? which one to pick? chris ma Everything Else 3 6th June 2003 12:06 PM
Copyright 1999-2017 diyAudio
