Mark Levinson 336 adjustment problem
Old 19th November 2009, 05:31 PM   #1
cmkc is offline cmkc  Hong Kong
Default Mark Levinson 336 adjustment problem
wanted ml 336 adjustment manual, due to replace some parts in the driver board, need to fine tune the dirver board trimmer, anyone know?
is the 336 like a 23.5 circuit? or someone know how to adjust 23.5?
Old 19th November 2009, 05:42 PM   #2
Mooly's Avatar
Looking at your circuit I would assume it's used to trim the offset to zero volts DC at the output.
The other obscure alternative is that it's used to minimise distortion by monitoring the output on a distortion analyser... whether that gives an offset error or not.
Old 19th November 2009, 05:52 PM   #3
Hi Mooly,
Thanks for reply, i assume too, it's for dc offset, but the problem is i cannot measure dc in the speaker output, because 336 have a dc servo circuit, so i don't konw its normal or not, anyone know where is the test piont on the dirver board?
Old 19th November 2009, 06:24 PM   #4
Mooly's Avatar
Measure here, the circuit as you posted has no servo
Make sure you use the correct ground as we are talking millivolts... use one that the feedback or input components go too.
Old 19th November 2009, 06:51 PM   #5
Thanks Mooly, i haven't 336 circuit, this is just 23.5 circuit for compare, i can't find the test piont in 336 ,
Old 23rd November 2009, 09:24 PM   #6
Find out by myself already!
Mark Levinson 336 adjustment problemHide this!Advertise here!
Mark Levinson ML9 problem vincentfrowijn Solid State 18 20th December 2016 03:54 PM
Mark Levinson JC-2 problem ( broken Line driver ) ken1967 Solid State 7 8th May 2013 10:17 PM
Mark Levinson No 27 Problem deafbykhorns Solid State 19 22nd January 2010 01:14 AM
Copyright ©1999-2017 diyAudio
