Who knows this amplifier
Old 18th November 2009, 06:41 PM   #1
Sergelisses is offline Sergelisses  France
Default Who knows this amplifier
Specification :
1. Mono, stereo system needs 2pcs of PA module,
2. Output power : Max 1000W RMS into 4 Ohm, Max 800W RMS into 8 Ohm,
3. Input sensitivity : 1.2V for 300W into 4 Ohm,
4. Harmonic distortion : 0.06% from 20Hz to 20KHz,
5. Frequency response : 17Hz - 56KHz at 0dB -3dB,
6. Supply input (DC) : 70V-0-70V (12A),
7. Using high quality BJT 5x 2SA1295 and 5x 2SC3264 from SANKEN,
8. high quality components (transistor, capacitor, resistor, relay, and etc.),
9. one by one tested,
10. heat spreader,
11. PCB 10x40cm2,
12. builtin turn-on delay and loudspeaker protection (DC servo),
Hello
Who knows this amplifier ?
Serge
Old 18th November 2009, 06:58 PM   #2
event horizon is offline event horizon  England
event horizon's Avatar
I can't see how it could output 800W RMS in 8ohms with a +/-70V supply It's obviously not a bridged amplifier with 5 NPN & PNP output transistors.
I think more like 250W RMS would be realistic with well regulated rails, if you used 2 modules bridged then yes, you might well see 800W RMS int 8 ohm.
70/1.414 = 49.5V, 49.5 squared = 2450/8 ohm = 306W but that's not taking into account any component losses at all
250W into 8ohm is far more realistic
"Never let your morals prevent you from doing what is right!" Salvor Hardin
Old 18th November 2009, 07:21 PM   #3
bekim is offline bekim  Albania
You have other modules @ ebay similar to that one.
BGR Blazer St Pro 2x 500W RMS Power Amplifier Kit DIY - eBay (item 160376004360 end time Dec-06-09 09:14:14 PST)
Who knows this amplifierHide this!Advertise here!
Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. novtango Pass Labs 4 14th February 2018 05:11 PM
Power Amplifier - Pre Amplifier Unity gain - Voltage gain - where as royal way ? tiefbassuebertr Solid State 9 9th June 2011 06:49 AM
Wanted: DIY amplifier builder with experience. I need a 0.7 ohm stable amplifier Audiophilenoob Swap Meet 34 16th May 2005 11:58 PM
