Old 18th November 2009, 02:13 PM   #1
DQ is offline DQ  Romania
Default diy heatsinks - please give some advices
Hello. I hope this is the right forum to post in, and please bear with me since I'm a diy beginner. I need a couple of serious heatsinks, each capable of dissipating 70W heat continuously, so I'd like to have a thermal resistance of about 0.25, certainly no more than 0.3 degrees C / W. Since they are quite expensive, I'd like to try the diy route.
Based on the materials locally available I am considering the following components (for 1 heatsink):
- 1 main aluminum sheet, 22.5 / 50cm (that's amplifier's height / depth front to bottom), 3mm thickness;
- 22 "teeth" 22.5cm in length (that's their height when mounted vertically), L shaped in section (4cm / 2cm), 1.5-2mm thickness. They will be cut from some (sorry for my English, it's too technical for me) stair grip like this - linked only for a better visual representation, mine are made of black anodized aluminum. They will be mounted with the smaller side (2cm) against the main aluminum sheet, using
- Arctic Silver Ceramique for better thermal transfer (that's a very big surface, more than 1000 square cm / heatsink, so I can only hope 1 syringe with 22 grams / heatsink will suffice) and
- many many rivets (I was thinking about 5-6 rivets / "tooth")
Now please advise me:
1. Do you think my attempt is realistic?
2. Do you have any particular recommendation to make?
3. Is Arctic Silver Ceramique a good idea on the long term or it might just dry in several years and force me to disassemble everything?
4. Do I need to fine sand or polish somehow the main aluminum sheet and the corresponding side of the "teeth"? (and if this is a must, although I'd very much like to avoid this, please tell me how to do it correctly as I have no clue how to do it other than by hand and then I don't know how make it smooth enough and how to avoid creating small surface irregularities, pits and dips...)
Thanks in advance for your support.
Old 18th November 2009, 03:08 PM   #2
pilli is offline pilli  France
I'm really no expert on the subject.
I just remember reading somewhere that rivets could be inferior to screws, because they may be not as tight in keeping the two surfaces in perfect contact. I have seen this in small TO-220 things "fixed" to their small heatsink with a rivet, that ends up losening.
Apart from that, you seem to have your ideas quite clear...
But still, just in case:
DIY Heatsink
HEATSINKS by SM0VPO
Old 18th November 2009, 03:43 PM   #3
destroyer X's Avatar
Default I have found that a square piece of aluminium... 2 milimeters thick, 10 centimeters
side, is able to dissipate 16 watts...enougth to a 10 watt RMS amplifier.
So....10 pieces of that will be enougth to a 100 watt amplifier..playing full power, continuous and undistorted (unclipped)..and the heatsink will not increase the temperature above 52 degrées celsius when your environment average temperature is 29 degrees celsius.
I have discovered, tested and found it perfect..since that (1969) i am using this method...even to evaluate heatsinks people send me as gift or parts from dismounted amplifiers or junk that i use to buy to use into some prototypes.
When evaluating heatsinks that have complex shape, i use to dismount them in my mind, and to calculate area exposed to the air...i use only one face to do that..each 100 square centimeters is good to 10 watts rms or good to dissipate 16 watts of heat.
regards,
Carlos
Dx Super A - Brazil - Layout Zimmer; http://www.youtube.com/watch?v=yxpYnUA6Bj0
Old 18th November 2009, 04:11 PM   #4
Magz is offline Magz  United States
If you have any old computer monitors lying around, they all contain some pretty massive heat sinks you can cannibalize. Just a thought.
Old 18th November 2009, 05:06 PM   #5
Bigun is online now Bigun  Canada
Bigun's Avatar
I've used superglue in the past to assemble heatsink pieces - if the joint is large so there is a good surface area for heat conduction and if you can clamp the pieces to ensure a thin and even coverage of glue...
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 18th November 2009, 08:02 PM   #6
lgreen is offline lgreen  United States
lgreen's Avatar
You can mix the arctic silver ceramique with epoxy to make a thermally conductive adhesive. I have done this before with success. If you clamp the stairs to the big metal and let it dry you should not have to sand. Try it with one or two and see how well it holds.
Why do you want to use arctic silver ceramique (not electrically conductive) vs. arctic silver (potentially electrically conductive under high pressures?). The regular artic silver has better thermal properties and I assume you don't care about electrical conduction for this application.
Assuming everything holds together it may work. It would be kind of funny if the fins started falling off though. Ok, that would not be funny. Maybe epoxy and a couple of screws or bolts.
Retired from DIY (2010) but still lurking now and again. My DIY audio projects- PartTimeProjects.com.
Old 18th November 2009, 08:07 PM   #7
MJL21193's Avatar
Making your own heatsinks can be cheaper, especially if you get the material for nothing:
But must be weighed against your time and safety. Working with aluminum, especially with power tools, can be dangerous and it is hard to justify the savings after you have been sitting in the emergency room at the nearest hospital for five hours.
Old 18th November 2009, 08:38 PM   #8
defect9 is offline defect9  Ireland
defect9's Avatar
arctic silver makes an epoxy (for attatching ramsinks to vid cards and such), no need to mix arctic and some other kind of epoxy
Old 18th November 2009, 10:05 PM   #9
Bigun's Avatar
Yikes - what happened ?
Old 18th November 2009, 10:14 PM   #10
MJL21193's Avatar
IT hasn't happened to me (knock wood) because I have a lot of experience, I'm very careful and I have the luck of the Irish...
It needs to be said whenever someone talks about working with metal, especially a metal that many of the members here think that it machines like wood. That is NOT the case. Wood can funk you up pretty good if it binds in the tablesaw and flicks back at you - aluminum becomes shrapnel in that situation, a potentially lethal projectile.
Be safe, it might be well worth buying that "expensive" heatsink.
About to begin 3-way project. advices please!! zafira1981 Multi-Way 17 31st August 2009 02:18 PM
Advices about speakers mafu Multi-Way 0 10th March 2008 12:11 PM
Beginner needs advices for 807 PP project oshifis Tubes / Valves 7 18th July 2007 10:28 PM
Need Car Amp Project advices lomtik Car Audio 1 17th June 2005 02:09 PM
General assembly advices ? volker Tubes / Valves 0 8th March 2002 08:05 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
