Old 23rd May 2003, 10:23 AM   #1
mrfeedback's Avatar
Default LM317 As Electret Mic Amplifier
A useful little circuit maybe - kills two birds with one stone.
Eric.Electret Mic Preamp
File Type: jpg 50_circuit_combines_power_supply_and_amplifier_.jpg (74.8 KB, 501 views)
I believe not to believe in any fixed belief system.
Old 23rd May 2003, 12:28 PM   #2
rather clever design
those panasonic capsules are pretty amazing for the price
intentionally blank
Old 23rd May 2003, 12:34 PM   #3
Circlotron's Avatar
But you'd have to be a bit of a sausage to use a voltage reg as an amp...
Stop posting silly circuits, mrfeedback.
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Old 23rd May 2003, 12:37 PM   #4
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Default Sausages and 'roo's united...
It's amazing it works with C1 in circuit!
Old 23rd May 2003, 12:42 PM   #5
Ever seen an amp with 15 - 47 µF on its output?
Old 23rd May 2003, 12:44 PM   #6
dhaen's Avatar
Perhaps if it's a Black-Gate, it'll be ok
Old 23rd May 2003, 01:05 PM   #7
Look at http://www.linkwitzlab.com/images/graphics/microph1.gif for the two standard ways to hook up an electret.
1) suggested by Panasonic uses the FET in common source mode, with a gain resistor in the drain connection:
+ gain
- distortion of the FET in common source mode
2) suggested by Sennheiser and Siegfried Linkwitz, uses the FET as a source follower with a 10 k load impedance:
+ lower distortion
- no gain
3) I have been thinking about replacing the 10 k with a constant current source:
+ even lower distortion
- higher parts count
- still no gain
The LM317-circuit gave me another idea:
4) Use the FET as it is, i.e. without disconnecting the membrane from the source. Connect the drain to a stable 2 V supply. Connect source to a virtual ground (negative input of op amp). The gain can be set through the feedback resistor. This hookup keeps the voltage across the FET constant and measures the current, just like the LM317. Haven't had time to look at typical FET curves. Would this by chance be more linear than 2) or 3)?
Old 23rd May 2003, 01:29 PM   #8
cm961 is offline cm961  Canada
cm961's Avatar
Me and a buddy are working on an electret mic project for recording drums. We plan on hooking up one little capsule per drum/cymbol, and mixing it all down to two channels. We had to modify the electrets a la linkwitz because the loud sounds were saturating the FET stage inside the capsule.
Although we're still putting it all together, the one mic that I did make was decent. They are supposed to have pretty flat response, so I'm wondering why studios etc don't use them regularily. At like $0.50 a pop, you can't go wrong.
Pete
Old 23rd May 2003, 01:51 PM   #9
schematics 3 & 4:
Old 23rd May 2003, 02:40 PM   #10
mrfeedback's Avatar
LOL.
DIY electret microphone capsule pre-amplifier EC8010 Analogue Source 4 26th October 2010 10:03 AM
4-pin mic converted to a 2-pin electret mic? silentblackhat Solid State 1 10th January 2008 06:50 PM
LM317 amplifier Russell Sit Solid State 3 5th June 2006 04:31 PM
Amplifier with LM317/337 voltage regs. DigitalJunkie Solid State 1 20th January 2005 11:36 AM
High Quality mic amplifier for Panasonic WM-60a electret? Toster Solid State 8 10th March 2004 06:29 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
