I have done some research on a bias circuit in a quasi complimentary circuit with two output vertical MOSFET's.
The bias circuit works well so long as there is not too much bais current in which case thermal runaway occurrs. With 20mA bias current it is very hard to get thermal runaway. I tested the circuit using a household iron to heat up the heatsink to above 70 degrees C and had no problems. However, with 90mA starting bias the bias current just kept on rising out of control. I used a simple Vbe multiplier with no emitter degeneration glued to the heatsink.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. Last edited by nigelwright7557; 17th November 2009 at 11:34 PM. |
#2 |
sounds interesting and I probably won't have a clue as to the issue but a diagram would help me follow along and contribute if possible.
Hopefully you'll have this ironed out soon
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#3 | |
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#4 |
Did it Himself
The source resistor is in the wrong place on your lower mosfet, it should be between the output rail and point where your cfp transistor joins the mosfet. This will help thermal stability of the lower half.
What have you got mounted on your heatsink? Outputs and drivers and bias generator? Or just outputs and bias generator?
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#5 | |
The driver transistors just have small bolt on heatsinks on them.
#6 |
Did it Himself
OK good, that is the preferred setup as generally it stops the drivers getting as hot as the outputs.
I can only suggest trying the modification I described to see if it helps. The rest of your circuit seems well thought out.
| Changing grid leak bias preamp to cathode bias | bereanbill | Tubes / Valves | 8 | 28th March 2009 06:26 PM |
| Bias problem- 1 Socket shows extremely low bias! | otokomae | Tubes / Valves | 12 | 31st December 2008 11:01 PM |
| Stray hum pickup *preamp* cathode R-bias vs. battery bias & 12AU7vs.5687 | awedio | Tubes / Valves | 2 | 19th April 2008 02:30 AM |
| Supressed bias amplifier, automatic variable bias system. | destroyer X | Solid State | 2 | 20th September 2004 11:24 AM |
| First tests with my 5ch GC | Mika | Chip Amps | 39 | 24th November 2003 02:05 PM |
| Page generated in 0.09232 seconds (75.76% PHP - 24.24% MySQL) with 10 queries |
