Old 17th November 2009, 11:18 PM   #1
nigelwright7557's Avatar
Default Baxandall diode information.
Can someone explain how the Baxandall diode works in a quasi complimentary amplifier ?
I have searched the internet and there appears to be a number of ways to implement this. Can someone supply a circuit of the original Baxandall diode circuit?
Many thanks in anticipation, Nigel
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 18th November 2009, 12:09 AM   #2
Hi
Isn’t the Baxandall diode a forward biased diode connected in parallel with the emitter resistor of the lower driver transistor?
I think the idea is that this will make the circuit work more ore less like a complimentary EF stage.
Old 18th November 2009, 12:13 AM   #3
Originally Posted by stinius View Post
Hi
Yes it is.
Old 18th November 2009, 12:18 AM   #4
Yes it is.
If we agree on that I don’t see your problem or what you are asking for.
Old 18th November 2009, 12:21 AM   #5
I jus twanted to understand the effect the diode has on the circuit.
Also I would have liked a circuit diagram of the original Baxandall implementation.
Old 18th November 2009, 02:10 AM   #6
Here is the circuit I ended up with after development.
I added the Baxandall diode but found I got some oscilation on the output.
A 220pf from collector to base on teh lower driver fixed this.
diode bridge - 10000uF cap - diode tube - small cap - HV+ engels Tubes / Valves 5 29th January 2008 11:16 PM
hybrid power supply: diode bridge into diode tube engels Tubes / Valves 8 24th September 2007 10:18 AM
DIY Baxandall network Craig405 Solid State 5 3rd September 2005 11:04 AM
Baxandall Eq brianti Analogue Source 3 2nd November 2004 03:38 AM
Baxandall series blmn Solid State 24 16th May 2003 07:41 PM
Page generated in 0.07720 seconds (78.37% PHP - 21.63% MySQL) with 10 queries
