DIY speaker cable question
Old 19th November 2009, 09:43 PM   #11
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
Why not just use something that isn't prone to blowing your amp up and is much easier to make?
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 19th November 2009, 09:45 PM   #12
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
how is it going to blow up your amp ? only way i see it is if you cross your cables
Old 19th November 2009, 10:16 PM   #13
Andersonix is offline Andersonix  Sweden
Andersonix's Avatar
Now you made me get out of my chair!
I found these beefy (nickel?) plated copper 1/4 inch ring terminals (which I modified into spades) at a surplus shop (Excess Solutions in Milpitas) for 20 cents each.
But in the past I have used these Vampire spades which are fairly minimalistic:
Vampire 1/4 inch spades
Attached pic also shows the white CAT3 (also 4 pairs of solid 24AWG like most CAT5) cable (someone gave me a huge roll) in a loose and tight braid.
Old 19th November 2009, 10:32 PM   #14
Banned
U should look at these,
Old 19th November 2009, 10:45 PM   #15
Andersonix's Avatar
I don't like those dual purpose (1/4 and 5/16 inch) types, as all my binding posts are 1/4 inch plus I like the slight clip-on effect from the spades widening slightly at the tips (but I'm being fussy).
Old 19th November 2009, 10:51 PM   #16
Jim Shearer is offline Jim Shearer  United States
Jim Shearer's Avatar
My interest in making speaker cables from CAT5 comes from seeing & hearing MJK's tube amp using home made cables using three braided CAT5's. It seemed like three would be tough enough to handle. And capacitance is additive in parallel--which is exactly what is going on here. Then there are the reports of these high capacitance cables blowing up some amps. Now my classic SS receivers from the early to mid 1970's may be more limited in band width than the fancy amps that got smoked, but I don't want to do something stupid and kill an amp.
AMPs that I might use these cables with include:
--Sansui 350A (from about 1972)
--Sansui 4000 (from about 1972)
--Yamaha CR-1000 (from about 1977)
-- Sonic Impact T-amp, gen 2
--MiniWatt tube amp
I ask because I would rather spend time learning, rather than learning by spending money to correct a disaster.
Thanks, Jim
A day without music is like a day without food.
Old 20th November 2009, 01:17 AM   #17
fastbike1 is offline fastbike1  United States
Just buy a roll of 16 awg zip cord and be done with it.
It you want to be tweakie, get the white "outdoor patio" 16/3 extension cord from Walmart. Cut the lengths you need, braid two of the conductors together and use these on the negative terminals, use the remianing conductor on the positives.
Read 6Moons if you don't believe.
I was so much older then, I'm younger than that now.
Old 20th November 2009, 01:20 AM   #18
Banned
thats a really good idea, LIKE WOW why didn't all of us think of that, ?
what a great idea, where have you been all these years!
Old 20th November 2009, 03:38 AM   #19
MNK is offline MNK  United States
He's been out listening to his speakers, not sitting around braiding wire and comparing copper to other copper.
Old 20th November 2009, 03:09 PM   #20
16 awg zip cord is exactly what I have been using for years. The reason for wanting to change is that Martin (MJK) brought over his tube amp to try on a couple of my speaker builds and brought along some cables he made using three lengths of CAT5 braided together. While the differences between the zip cord and the CAT5 were not overwhelming, they were significant (persistent and repeatable.) I won't spend many hundreds of $$ chasing this, but am willing to drop $50 for a 500' spool of CAT5, plus some spade lugs and banana plugs, and invest my time.
My concern is with the zobel termination so I don't kill an amp in the learning process.
Thanks for all the comments,
Jim
DIY speaker cable questionHide this!Advertise here!
cheap cat5e cable for speaker cable fishline Full Range 6 19th May 2009 07:42 PM
problems with speaker cable as power cable pjpoes Parts 11 14th January 2007 08:24 PM
25 pair cat 5 cable for speaker cable? mpmarino Parts 19 3rd March 2006 04:46 PM
NAD 320BEE and speaker cable question AllCaster Solid State 0 9th January 2005 03:45 AM
Speaker cable question with Gainclone? Fragen Chip Amps 1 29th April 2004 11:36 AM
