Old 20th November 2009, 09:34 PM   #21
GEirin is offline GEirin  Argentina
Carlos
To see thread:
Modify my old 80 amp of ECBLN
Saludos
Guillermo
Old 21st November 2009, 03:17 PM   #22
Hola Carlos.
Here link.
modify my old 80s amp
Saludos.
Guillermo
Old 29th November 2009, 12:05 AM   #23
wahab is offline wahab  Algeria
hi,..buffering the vas bring vast amount of open loop gain, so
the negative feedback is more efficient to reduce distorsion..
sadly, there s lot more phase shift, making the circuit prone to
oscillation...the solution is to increase the dominant pole capacitance,
thus reducing the high frequency open loop gain and so rendering
the buffer useless..the best is to use one high gain transistor
to do the work...
Old 29th November 2009, 05:10 AM   #24
AKSA is offline AKSA  Australia
Yes, Wahab,
Reluctantly, I think I agree with you. Best device for 8-15mA VAS stage current is a very low Cob, fast transistor like the 2SC3423.
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 29th November 2009, 05:27 AM   #25
Bigun is offline Bigun  Canada
Bigun's Avatar
I think a more interesting course of investigation would be to have two Cdom capacitors, not a dominant pole but a split pole. Self waxes lyrically about this for low distortion.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 29th November 2009, 05:41 AM   #26
CBS240 is offline CBS240  United States
CBS240's Avatar
to do the work...
This is where the cascode (common base) VAS comes into play. You can use a low voltage transistor for the amplifying device. It is much easier to find a fast, high gain, low noise transistor with a low Vce requirement. And besides, cascode has other benefits too, such as negating the Early effect by maintaining a constant Vce on the amplifying transistor.
All the trouble I've ever been in started out as fun......
Old 29th November 2009, 07:41 AM   #27
I can agree with the low voltage, high speed transistor observations, but these days there are good devices rated to high speed and voltage, and in listening tests between single VAS and cascoded VAS I never found any advantage at all, and a small cost in headroom with the VAS. There is a small advantage in THD, but it's not audible.
The single, common base VAS - here is an advantage I've noticed in listening tests. More nimble and quieter, but compensation is not easy.
www.aksaonline.com
Old 29th November 2009, 12:10 PM   #28
yes hugh, i was reluctant too about the one trans solution....
the bjt you re proposing is just perfect for the job..
currently, i m designing a symetrical differential using a cascode
in the vas, as suggested by CBS240 , but there s some serious
ill-effects near the zero crossing point as soon as the load
is reactive, and i m struggling making the damn thing linear..
and as proposed by BIGUN i choosed to not use a classical
lead dom pole capacitance , i.e from base to collector of the vas,
but rather using two capacitances in two different paths
of negative feedback...
i already use this compensation scheme in the same amp
but with a classical vas, with no cascode....it works
very fine...i ll publish schematics in an another thread, as
a discussion about topologies...
Diamond Buffer - Super Buffer peranders Solid State 34 16th May 2010 02:46 PM
Near ZERO IMD buffer amp wenye Solid State 37 20th April 2009 08:50 AM
Opamp + buffer, how to bypass buffer at HF for unity gain? Christer Solid State 10 29th October 2003 07:50 AM
Op-amp Buffer johnferrier Solid State 30 28th October 2003 06:38 PM
OP + buffer Holger Barske Solid State 13 3rd November 2001 10:13 AM
Page generated in 0.10244 seconds (82.39% PHP - 17.61% MySQL) with 11 queries
