#11 |
Banned
forr,
If so, it´s deeply deplorable, the always present conflicting factors should be shown and taken into account. |
#12 |
Hi Hugh,
Thanks for your advice. However my main question still remains : why is a VAS follower loaded by a CCS is almost not used, even in the D. Self's published schematics ? In his 5th edition book, Self praised the White follower. Its default of having a low PSRR (my simulation shows about 30 dB for single transistors and 50 dB for Szilkai pairs) can probably adequately got around using a clean power supply and/or a lot of low frequency NFB. What do you think ? Hi Lumba Ogir, Could you tell what are the negative factors as the positive ones are already known ? |
#13 |
I had bad results simulating.
regards, Carlos
My Youtube channel; http://www.youtube.com/user/destroyersoueu?feature=mhee |
#14 |
Destroyer X
Esta es mi copia de manual en pdf. Manual in PDF |
#15 |
Destroyer X
Aquí amplifier........... |
#16 |
#17 |
regards,
Carlos
#18 |
Nice bootstrapp uncalibrated...there are several interesting solutions applied.
I will assemble.... will be the next to be tweaked for sonics. This one is a promisse of high quality, excelency in measurements, for sure..we gonna see the sonics. thank you Geirin. regards, Carlos
#19 |
Hi Destroyer X
Hola hermano. I wait for you "investigation". You could consider mod darlington output. To use DX amplifier output stage. What is your opinion? Cheer Guillermo |
#20 |
I felt in love by this circuit...it looks better than mine.... maybe will sound better, and this i want to know.
If really sounded better..hehehehe..new Dx will born..will be Grundig by Dx.... Grundex!... will migrate from Aksadex to Grundex..ahahahahahah! Interesting solutions applied, double bootstrapp, but with different values related positive and negative side...this may be because selecting harmonic distortions to fell into nicer frequencies.....well, there are a lot of things i loved in this unit. Passion..... i will try to find this unit in Brasil.... i would like to buy the unit.... i think this amplifier is impeccable.... about the sound..only listening and tweaking. regards, Carlos
My Youtube channel; http://www.youtube.com/user/destroyersoueu?feature=mhee Last edited by destroyer X; 20th November 2009 at 12:27 PM. |
| Diamond Buffer - Super Buffer | peranders | Solid State | 34 | 16th May 2010 02:46 PM |
| Near ZERO IMD buffer amp | wenye | Solid State | 37 | 20th April 2009 08:50 AM |
| Opamp + buffer, how to bypass buffer at HF for unity gain? | Christer | Solid State | 10 | 29th October 2003 07:50 AM |
| Op-amp Buffer | johnferrier | Solid State | 30 | 28th October 2003 06:38 PM |
| OP + buffer | Holger Barske | Solid State | 13 | 3rd November 2001 10:13 AM |
| Page generated in 0.10117 seconds (79.54% PHP - 20.46% MySQL) with 11 queries |
