#61 |
lgreen the amp looks real nice by the way.
Just noticed that this person got fake Sankens from MCM: Another high DC Adcom GFA-555 Anyone know of a reliable source? |
#62 |
Great, something new to worry about -fake Sankens!
To provide an update- I am still waiting for someone else to build one of these so we can compare data. I have received a few emails off-line so I know people are working on them. I have also received emails off-line from others concerning interactions with and the personality of the original poster, but I'll not get into that here.
My DIY audio projects- PartTimeProjects.com. |
#63 | |
If you give a man a fish he will eat for a day. But if you teach a man to fish he will buy an ugly hat. And if you talk about fish to a starving man then you are a consultant. Dilbert |
#64 |
yeah right, images ...
#65 |
GK posted this on another forum and I thought it might be of help:
I noticed that you resurrected the "ExtreemA" thread. I haven't the stamina to read through it all, but has anyone asked Lgreen what kind of preamp/source or signal generator he is using? The reason I ask is that the amplifier uses shunt feedback. What this means is that if the source is disconnected from the input, the amplifiers input resistors are un-terminated, and the amplifier reverts to a closed loop gain of unity. Unless the amplifier is frequency compensated for unity closed loop gain (very unlikely) that will turn it into an instant oscillator. Also, a lot of test bench audio signal generators have an output impedance of 600 ohms. The ExtreemA's input/feedback resistors are 1k. 600 ohms in series with that would result in a substantial closed loop gain reduction of 1.6 times. That could very well cause the oscillation that he is seeing. He also mentioned: There are a few things with that design that are a bit suspect; The cfp VAS buffers (making these with to-92 BC5** parts in my experience often makes an oscillator), no zobel or output inductor. |
#66 | |
The preamp is a Krell KRC-2 and source is Wadia 301 (through preamp or not, results are the same). Also tried with my X-CCS-BOSOZ (same results). The test bench signal generator is a Tektronix FG-501A. Is it thought a zobel would correct the issue? What zobel values should be tried? Would you put in two zobels to ground or one zobel from + to - output? To summarize for everyone so you don't have to reread everthing, under normal circumstances the amp is fine, no oscillation with no input or short circuit or even any input other than one sufficient to cause the signal to approach the rail voltage. So unloaded there are no issues (despite the theory above). There are no issues unless you are very near clipping. As the rail voltages are neared an oscillation slowly forms.
My DIY audio projects- PartTimeProjects.com. Last edited by lgreen; 13th June 2010 at 09:44 PM. |
#67 |
I wouldn't worry too much if the behavior is only at clipping as one shouldn't operate there most of the time!
As for getting distortion mesurments try using a computer! something like the creative SB24bit can be purchased for 15$ and has crazy low distortion: Buy Creative Audigy SE | Creative Labs Online Store (UK) Couple that with software like rightmark and a voltage divider you have a relativly easy to use high resolution mesurment card. |
| Hitachi Servo/RF-Amp HA12158NT ("HA 12158 NT", HA12158, "HA 12158NT") from Linn Karik | tiefbassuebertr | Digital Source | 6 | 27th June 2011 01:14 PM |
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 06:42 PM |
| Please comment on my "built-in" subwoofer idea | weinstro | Subwoofers | 5 | 28th September 2007 04:28 AM |
| Some final pics of "Stacks" revisited and "Askew" with stand | Andy G | Multi-Way | 2 | 3rd February 2005 06:07 AM |
| Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? | Ignite | Multi-Way | 3 | 18th November 2001 08:42 AM |
| Page generated in 0.11989 seconds (80.53% PHP - 19.47% MySQL) with 11 queries |
