Old 16th November 2009, 10:47 PM   #1
Default sima amplifier questions
I have an amplifier made in the early 80's by Sima Audio of Montreal, Canada. The model number is AB200 and appears to be 100W/ch into 8 ohms.
I rescued it from a local rock'n'roll band (who thought it was a tube amp!) just for the enclosure and power supply, but after looking at the amplifier sections it seems worthy of refurbishment.
It has been around the block a few times but as far as I can tell it has never needed repair (until I started tinkering with it, sigh).
I have reversed engineered the schematic from the pcb (hopefully attached) and I have some questions which I will follow up with.
Old 17th November 2009, 12:03 AM   #2
Rafael L's Avatar
What are questions?
Old 17th November 2009, 12:50 AM   #3
1. While playing with the bias adjustment, I went too far and 2N6553-Q6 died (shorted). Is this an inherent limitation of this bias design circuit, or was it just an old (underspec'ed perhaps?) component operating on the edge?
2. I think 29113/114 would be a suitable replacement TO3 for the 15003/004, but what about replacing the 2N6553/6556 drivers with MJE15030/31? The bias circuit also uses the 6553/6556, what is a suitable replacement for these? I anticpate mods to handle the different pinouts on newer devices of course.
3. Why does the high side driver Q6 have a base resistor R9 but the low side Q7 does not? (I am just starting to read Self and Slone books about the theory of operation...)
Old 17th November 2009, 01:49 AM   #4
Miles Prower's Avatar
Since it's operating into just 47R of emitter resistance, there isn't much in the way of current limiting. Should have had either more emitter resistance or a transistor with a higher Pc rating.
Looks like a quick 'n' dirty fix for oscillation. Putting a base stopper there fixed the problem, and so they didn't bother to add one to the other side.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 17th November 2009, 01:05 PM   #5
Hmm, thanks for the info.
Just adding a pic of the internals, check out the heat sinks.
Old 17th November 2009, 05:59 PM   #6
Laszlo Ferencz's Avatar
Nice find!
I'm interested what are the spec's of the power transformer and PSU caps (these huge blue ones)?
Old 17th November 2009, 10:37 PM   #7
Originally Posted by Laszlo Ferencz View Post
Nice find!
The transformer has a nameplate rating of 371VA (exactly!) at 75Vct. The caps are I think 10000 uF at 63V (85V surge). No ripple current rating though.
With no load, the rails are at +-56V, clipping at 30.5Vrms.
With only one channel driven with a sine wave, it clips at 30.1Vrms into 8 ohms (52V rails) and 29.5Vrms into 4 ohms (49V rails).
The 8 ohm load showed 220W input on the primary and 405W with the 4 ohm load, basically only 50% efficient end to end.
I need the Sima W-3050 or W-2002 schematic gaetan8888 Solid State 11 11th April 2010 04:10 AM
amplifier questions Professor smith Pass Labs 14 14th November 2008 02:32 PM
Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. novtango Pass Labs 2 21st October 2002 01:50 AM
Page generated in 0.10688 seconds (75.81% PHP - 24.19% MySQL) with 11 queries
