Hi to All
I have a different consumption Ib PNP/NPN in my amplifier in the output stage, I can not know the reason. Initially thought the VBE multiplier would cause, I shorting VBE multiplier, but the difference remained...later tried equal gains PNP/NPN (BF in simulator) but, difference continues The figures can better understand the problem. Thanks |
#2 |
drivers Ib or output Ib?
Have you measured the gains of the transistors before you fitted them. Did you measure the gains are the expected collector current that the amp would pass?
regards Andrew T. |
#3 | |
Hi Andrew
See the simulation in Trs of output |
#4 |
Have you measured the real devices?
Have you measured the real voltages?
regards Andrew T. |
#5 |
#6 |
we all know that models are only as good as your ability to check whether they do model real behaviour.
If you can't check that, then you should NEVER rely on a computer model, especially if someone's life depends on the answer.
regards Andrew T. |
#7 |
Hi
The problem was the models actually, used the Andy_C models (2s4793/1837 and MJL3281/1302), the difference between PNP/NPN this OK. PS: In simulations that have different Ib, I used models Fairchild Attached simulation Ib drivers Thanks |
#8 |
The base currents of the output transistors will be "mirror images" only if the output transistor are exact complements. Therfore, you should expect different base currents.
| 3C24 in a SE output stage - output transformer impedance recommendation !!! | aldovan | Tubes / Valves | 15 | 6th September 2008 10:18 AM |
| preamp output stage resistor from output to V- ? ? | Bernhard | Solid State | 4 | 19th October 2007 02:55 PM |
| Output stage biasing, with the driver stage | andrew_whitham | Tubes / Valves | 0 | 19th May 2007 11:14 AM |
| Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 | freddymac406 | Tubes / Valves | 3 | 21st April 2007 06:15 PM |
| TV Horzontal Output Transistor for output stage..? | ronybc | Solid State | 46 | 10th October 2005 02:26 AM |
| Page generated in 0.09402 seconds (75.26% PHP - 24.74% MySQL) with 11 queries |
