Old 13th April 2010, 04:09 PM   #671
PMA is offline PMA  Europe
PMA's Avatar
Originally Posted by Federmann View Post
Current limit is more than 13A?
Yes. It is determined by F4A fuses
Pavel Macura, consultant
http://cz.linkedin.com/pub/pavel-macura/4/783/637
Old 13th April 2010, 04:17 PM   #672
Federmann's Avatar
Send a message via ICQ to Federmann Send a message via Skype™ to Federmann
OK Pavel!
But the current no limitation on amplifier.
Old 13th April 2010, 04:32 PM   #673
PMA's Avatar
This amplifier is only for me and for my purposes. The current is limited only by PSU and fuses, and paralleled transistors have such SOA that they withstand short circuit (tested), with quite low supply voltage used.
If I built that amplifier for a customer, it would have a current protection circuits. Now it is just a research stage
Old 13th April 2010, 04:52 PM   #674
PMA's Avatar
Bohumil,
I have made a research test, just for you. 10Hz sine with gradually increasing amplitude, into 0R22 load. You can see the peak current when the power supply rail fuse has blown, it is about 20A peak
Old 13th April 2010, 05:10 PM   #675
Federmann's Avatar
When will the next amplifier, I also do interesting tests.
Old 13th April 2010, 05:38 PM   #676
Federmann's Avatar
Originally Posted by Sendy View Post
400Hz sinewave, 80% output voltage with no load and with load 0,1 ohm, 5-10 sec duration.
To the impossible!
Current will be limited to less than 20A. Voltage on the load will be less than 2V. After a few ms off fuse!
Apply what I wrote.
Old 16th May 2010, 06:41 PM   #677
Sendy is offline Sendy  Czech Republic
Hi Federmann, what about testing your "overcurrent protection" ? Now you have a new piece of amplifier, what about measuring ?
Old 30th July 2011, 09:55 PM   #678
Federmann's Avatar
Measurements up to 200mΩ.
Old 30th July 2011, 09:57 PM   #679
Federmann's Avatar
Measurements up to 500mΩ.
What is the influence of your listening room? massive Multi-Way 15 12th January 2003 03:25 AM
Page generated in 0.10146 seconds (73.58% PHP - 26.42% MySQL) with 11 queries
