Old 4th January 2010, 03:08 PM   #541
Federmann's Avatar
Send a message via ICQ to Federmann Send a message via Skype™ to Federmann
The result is not very good. It is good to 50V, there is Vdif 2x24mV. When the output voltage of 86V is Vdif 83mV and it is very much.
Old 4th January 2010, 03:11 PM   #542
Federmann's Avatar
Originally Posted by Upupa Epops View Post
That's nice, Federmann...and with output mosfets ?
"And with output MOS-FETs" No worries, the result is very similar.
Old 4th January 2010, 03:32 PM   #543
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Federmann,
Vdif is the effective input signal. Of course, if you increase the output voltage, Vdif MUST rise in proportion (within the linear range of the amp).
So if your Vdif is 46mV with 50V output, that shows an open loop gain of just above 1000. (Actually 1087 exactly). With 86V out, and the same open loop gain, I would expect a Vdif of 86/1087 = 80mV. That's close enough to your measured 83mV I would think.
jd
/Another new issue: Linear Audio Volume 3!
Old 4th January 2010, 03:45 PM   #544
Federmann's Avatar
Amplification stages are not linear. Greater Vdif represents a decrease gain.
2 x 24mV = -10%
83mV = approx -20%
48mV, the third harmonic output voltage 10%, 1% output power.
83mV, the third harmonic output voltage 20%, 4% of output power.
Old 4th January 2010, 03:57 PM   #545
Federmann's Avatar
Open loop, gain decreases the frequency but also decreases the size of the output voltage, accurately the size of Vdif.
Old 4th January 2010, 04:46 PM   #546
janneman's Avatar
Correct. The gain decreases slowly with increasing output voltage. I just didn't want to bring that secondary effect into it yet. It's called gain compression.
Since the OL gain also rolls off with frequency, you will also see the Vdif increasing in ratio with frequency. ALL amplifiers will show this to varying degrees, as I'm sure you know.
jd
Old 4th January 2010, 05:44 PM   #547
Federmann's Avatar
The precise setting Vdif without a signal, using P - I controller, everything is much better.
Old 4th January 2010, 06:39 PM   #548
janneman's Avatar
Not sure I follow you. The only Vdif without signal is the DC offset.
jd
Old 4th January 2010, 07:26 PM   #549
BV is offline BV  Slovakia
"P - I controller"
Yes, he means DC servo, to hold conditions in the midlle of linear region, and he is believing this should improve also hf linearity..
Old 4th January 2010, 08:30 PM   #550
janneman's Avatar
Originally Posted by BV View Post
"P - I controller"
Ahh yes, thanks!
jd
What is the influence of your listening room? massive Multi-Way 15 12th January 2003 03:25 AM
Page generated in 0.10242 seconds (82.79% PHP - 17.21% MySQL) with 11 queries
