100% agree, Pavel..
I extensively played on stage, and from my experience,
output short circuit is not a likelyhood, but a certainity.
The only question is not if , but when will it happen..
One has to take a look at a PA pro amp, there s often more
components for protection circuitries than for the amplifying
purpose itself...
purpose itself...
I repeat that a normal person can not operate long into the amplifier to short-circuit.
Mr Federmann, a suggestion:
You are no doubt a smart person but your language handicap prevents meaningful discussions here.
Why not spend one hour each week in an English language class?
You will gain the time spend many times back here (and maybe in your job).
best regards,
jd
Oh no, but PA2 is only 2 x 55W amplifier. I assume that Sendy was meaning your 1kW amplifier (you have 20x more power than PA2), which is much more capable to yield high currents.
55W = 42Vp-p.
You showed very nice sinus, there is no current limit.
no,55W = 42Vp-p.
55W into 8r0 is equivalent to 29.7Vpk = 59.3Vpp.
55W into 4r0 is equivalent to 21Vpk = 42Vpp.
You must specify the power and the load for the information to be of any use.
Then I have measured quite nice 13Apeak output current
Which occupies the current restrictions? Is not seen working?
How much is the rail voltage? How much power is the amplifier?
Federmann, in case you would like to test with 0R22 load, please take into account that such load may change stability of the amplifier significantly.
No worries.
27-5,83≈21V, Transistor power 21V*13A=273W
In your 55W amplifier it is 2 * MJL21193/94 ? (2 * 200W +2 * 200W?)
Current limit is more than 13A?
PMA: What is your transformer, please?
Performance on 1 channel 27V * 13A ≈ 350W
Performance on 2-Channel 700W?
Yes. It is determined by F4A fuses
OK Pavel!
But the current no limitation on amplifier.
This amplifier is only for me and for my purposes. The current is limited only by PSU and fuses, and paralleled transistors have such SOA that they withstand short circuit (tested), with quite low supply voltage used.
If I built that amplifier for a customer, it would have a current protection circuits. Now it is just a research stage
400Hz sinewave, 80% output voltage with no load and with load 0,1 ohm, 5-10 sec duration.
To the impossible!
Current will be limited to less than 20A. Voltage on the load will be less than 2V. After a few ms off fuse!
Apply what I wrote.
When will the next amplifier, I also do interesting tests.
Hi Federmann, what about testing your "overcurrent protection" ? Now you have a new piece of amplifier, what about measuring ?
- Influence of the delay amplifiers for listening characteristics
